randomspeedfreak
Gti6 Power Loss Troubleshooting
randomspeedfreak
So had my gti6 conversion on the road for a 6 months or so now. Recently, I have a consistent problem with the car, please have a read and offer your 2p if you can
Around a month ago the car started to cut out on part throttle, it would loose power for consistently around 5 seconds, as if it was fuel starved, then abruptly come back to normal power. If you applied full throttle quickly this would clear up, if you were driving quickly it would be fine (aside from a slight loss of overall power and torque,,,but thats only seat of pants test no rolling road to confirm) it feels like the car is lean when running - if you are flat out, then back off ever so slightly, it seems to richen slightly and not decelerate for a second
In addition to this it will do this when its sitting on idle, it would go lumpy, then drop to 3 cylinders, then 2, then one then cut, all over the space of around 20 seconds, when it does this you can hear the ICV hissing more and more as it gets closer to cutting. if you quickly apply enough throttle it saves it and it returns to idle for around 30 secs, then does the same again. If you slowly and gradually apply throttle it still dies, even if you get to full throttle
It would only do this after it was warmish, after the second sector on the temp gauge, when cold behaves fine
what i have done:
Tested and replaced green sensor - both sensors passed test, also same behavior with either
Performed fuel pressure test - consistent 2.2 bar spiking to 3 bar as it should be i gather,
tested throttle position sensor - results came out as they should between 0.6v and 4.93v
changed throttle body (maf and throttle position sensor) - seems to have more power and torque across the rev range,
tested map sensor - seemed to perform correctly, the sensor spiked voltage when manifold pressure changed sharply however cannot confirm if it isnt slightly out
Changed icv - the spare icv i changed to was obviously stuck, engine sat at about 3 krpm when this one was fitted. cleaned and replaced the original one, it idled lower at first, then didnt stall for a while, then returned to bad behavior
Points of note:
Lambda sensor is one installed by previous owner - it is a non oem one, and has had the wires cut and soldered at some point - I was planning on changing this anyway
Wiring loom: my wiring loom is currently a mess. I had trouble converting my phase 1 205 loom to work with my already butchered phase 2 205 to gti6 loom. all connections are properly done by me - heat shrinked etc, but i cant rule out that some wires havent fallen apart on the inside when disturbed
Engine is a tapper, may have some effect?
Any advice or ideas welcome
Cheers,
Matt
dcc
Might be the split in the downpipe collapsed. Could be the fpr. Could be fuel pump. I think these are meant to run 3bar, so seems like a fuel issue. Its not unheard of that the fuel lines are restricting flow if theyre old too.
2.2 bar fuel on idle sounds about right as they have the vacuum pipe to the plenum, should be 3bar on wot.
there is no maf, guess you meant I.a.t sender?
try it with the lambda unplugged.
randomspeedfreak
Thanks for your replies gents,
Could you please explain the split in the downpipe part? did you mean inside a fuel line? I agree seems fuel pressure or fuel delivery related... however the fact it only happens on part throttle has led me to believe that it isnt a fuel line blockage? would have thought that at a higher throttle opening, the required fuel flow rate would be greater, and therefore the problem worse?
This is the result i got running a fuel pressure gauge in parallel to the line. I will repeat the test for clarity but im sure it was a pass.
yes my apologies, I ment the air temp sensor
When I unplugged lambda it idled correctly, fuel consumption increased as expected, it is clearly running richer. Although it no longer stalls, I couldnt confirm that this was the cause of the issue, just that it had enriched the mixture enough to avoid the symptoms. I now realize didnt actually drive it with it lambda unplugged. I will try this on the way home and see if it solves the power loss when driving issue...would your money be on that as the culprit then?
Thanks again for the help guys
Edited by randomspeedfreak
its possible, the symptoms do point towards somethign altering the fuelling drastically after it warms up, the lambda is only used once the car reaches normal operating temperature.
It does appear that lambda wiring does not take to being soldered typically, cutting the joint out and adding some quality crimps might fix it, you need to pay an extra little bit to get a direct fit Lambda rather than one without a plug sometimes.
randomspeedfreak
ok ill get a new lambda to start with
This morning the car stuttered badly whilst cold! GRRRRR!
maybe this is a combination of multiple problems?
Will try with lambda disconnected now
Thanks again,
Matt
Lambda sensors need to draw fresh reference air via the wiring and soldering prevents that.
camgti
Exact symptoms of mine.
Replaced and tried all the things you have done.
Changes the lambda to an OEM one and its perfect.
Definitly change it. Or drive the car with it unplugged.
Unplug it, disconnect battery to reset the ecu and try that.
All pointing to Lambda.
Cam
Edited by camgti
macaroni
Another vote for lambda sensor, exact same symptoms as mine, cured by a new lambda.
randomspeedfreak
Ok thanks guys, bosch lambda arrived today, will fit tomorrow and report back - car has been behaving well (if a little thirsty!) with lambda unplugged so all signs point to that i have my hopes up
Cheers gents,
Matt
randomspeedfreak
Lambda fitted, problem solved! more power and torque across the rev range! no stalling! better fuel economy!
thanks a million for your help gents, cracking forum
Cheers,
Matt :D​
camgti
Great news!
