sef 0 1 Cars Posted February 21, 2015 Can anyone help with a diagnosis on this please? Standard unmodified 1.6 GTI - fan doesn't come on. I've disconnected the (3 pin) thermoswitch and bridged the contacts. Fan doesn't start. Unplugged fan lead from its connector (the grey one behind the n/s headlight). Multimeter shows 12V on the female side of that connector but fan doesn't work when plugged back in. Same result from bridging contacts on the brown test plug. But the fan works every time if I connect it direct to the battery. Any ideas of what else to look for would be appreciated. Thanks Share this post Link to post Share on other sites
welshpug 1,737 Posted February 21, 2015 checked the continuity to earth? 1 Share this post Link to post Share on other sites
mrfirepro 127 1 Cars Posted February 21, 2015 I had a similar issue, problem was one of the connectors, should have had two cables connected to it but one of the cables had broken away from the connector, didn't realise until I started following the wiring diagram. Soldered the broken wire into the existing wire and it all worked again. Share this post Link to post Share on other sites
sef 0 1 Cars Posted March 1, 2015 Thanks welshpug, you were right. It was a dodgy connection on the earth wire where it plugs in near the headlight. Cleaned up the contacts and back to normal again. Share this post Link to post Share on other sites
