vkchill
Help! Nm On Headbolts
vkchill
Hi. Does anybody have the nm on a xu9jaz dkz, torx headbolts??
60nm
Back off
20nm
+300degrees
Ensure all threads are lubricated with engine oil
I always do the 300deg in three stages, all of them 90deg, all another 90deg, then all 120deg
vkchill
Thanx man :-)
stumpyjag
Make sure lots of engine oil between the spacers and the bolts as well or they will bind and stop you reaching 300 degrees. I found 300 degrees is a long way and you feel you are going to break something so anything to stop things binding is a big help.
wicked
Check the bolts 2 or 3 times for the 60/20Nm in the prescribed order.
If you have done the last bolt to 60Nm in the first round, the first bolt will be back at 50Nm or so, since the head has clamped more to the block.
no need to do that, that's why the tightening order should be followed.
vkchill
I followed Toms advice. And used oil on the spacers and bolts, hopfully it will turn out great
dcc
worth cleaning the threads out by running a bolt through them a few times with some oil too
