Slo 283 1 Cars Posted February 15, 2015 Just got myself a pp2000 and after a bit of reading it seems that the software will only work on windows xp or a virtual environment running on another os (vista 7 8 linux). Been waiting all day for xp to install andupdate in this virtual pc thing just so i can even test this diagnostic device actually works. God why did they make this xp only. The software is a nightmare to install and set up Share this post Link to post Share on other sites
James_K 6 1 Cars Posted February 15, 2015 As I remember it takes forever to install and you'll think the pc has crashed at several points. It works well once installed though Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 15, 2015 (edited) Ive ditched the pp2000 standalone software and gone with the diagbox setup. After installing virtual pc and xp with all its updates i've been sat in front of my laptop since 12:20 this afternoon and its only just got to the pp2000 install. Edited February 15, 2015 by Slo Share this post Link to post Share on other sites
James_K 6 1 Cars Posted February 15, 2015 I don't think i ever bothered with diagbox, pp2000 was easy to use if you persevere with the setup, especially as instructions are thin on the ground Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted February 15, 2015 There's a guide on 306oc on how to use it Got a working copy myself, brilliant bit of kit. Pp2000 work's just fine Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted February 15, 2015 http://306oc.co.uk/forum/showthread.php?tid=2752 1 Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 15, 2015 Brilliant thanks for that paul im just updating diagbox to latest version now Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 16, 2015 One thing I experienced is that Diagbox is slow compared to PP2000. On my 407, using Diagbox 5.X version I launched PP2000 from Diagbox and has all features avaliable. But when I upgraded to Diagbox 6.X, I could not use PP2000 anymore for most tasks (launched from diagbox still), and Diagbox is painfully slow. However two virtual PC's running both Diagbox 6.X and 5.X is a good solution to read both old and new cars Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 16, 2015 (edited) Yes i saw how diagbox is terribly slow, have deleted it now and installed pp2000 but it wont start because it cant see the tool on usb. How do you pass through usb devices in virtual pc? No matter what ive tried it just wont see the tool. Its installed on windows 7 btw and 7 is ding donging when i plug in and remove it. Actia usb device - usb com board driver (UDMF). Got it to install in the xp but its still not seeing it ffs. XP ahhhhhhhhhhhhhhhhhhhhhhhhhh pos Edited February 16, 2015 by Slo Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 16, 2015 Can't remember exactly, but in the settings for the virtual PC image, I assume you use Virtualbox?, you need to enable USB for the virtual PC. You should get a "VirtualPC USB" object or something on the list on the device manager list on your physical PC. In the virtual PC the adapter should then be recognized as the Actia USB device... Not sure if it might be a problem that the actia USB device is already connected on the physical PC, maybe it might get a conflict? I never installed the Diagbox/Actia driver on the physical PC. Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted February 16, 2015 http://m.youtube.com/watch?v=XUIZ5sZmbpI Might help There's loads of info of you search on Google Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 16, 2015 Only way i could get it to install in the xp was to uninstall it on the host 7 and attach the unidentified device to xp which it saw and installed instantly but oddly as soon as it had finished 7 bing bonged as well and installed it at the same time. Still not working, ive read the cheap chinese replicas which this obviously is are blacklisted from the software by the serial number from a certain builld number. Oh well only thing left to try now is dual boot os when i finish work at midnight. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 17, 2015 Finally got it working properly booting straight into xp on a dual boot, only problem is my laptop doesnt have any support for xp so there arent any drivers for anything at all which means no internet access while im using diagnostics :/ Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 17, 2015 Ok. I would spend some more time on getting it to work on Virtualbox if I were you. I actually prefer to use it on Virtualbox as it does not occupy the whole screen, keeping the virtual PC to a limited part of the screen on the host. Always been annoying that PP2000 / Diagbox is occupying the whole screen. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 17, 2015 Ive tried and tried. I can get it to install the actia driver on the host 7 or virtual xp but not both at the same time and the xp install is saying the pp2000 isnt connected or is already in use. over and over and over spent many hours on this twatting thing now Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 17, 2015 You need to uninstall the driver on the Win7 host I think at least. As the virtual PC only needs a generic virtualbox USB device to be "installed" in the Win 7 device manager. Then the virtual PC should have the Actia drivers installed. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 17, 2015 Done all that, as soon as you attach the usb to xp it dissapears from 7 and appears in xp but pp2000 saying not connected or in use Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 17, 2015 Strange. I can try to get the Virtualbox settings file from my image next time I start the diagPC if that would be to any help, I should have fired it up and done some fault reading on a 308 anyway. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 18, 2015 Tried and tried everything again and again till 5am this morning and no better off from when i started so i've given up and bought an old s*itter xp laptop off ebay for £14 just to run this. Will update this when it turns up. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 19, 2015 Ok borrowed an old laptop with xp on it for the time being and pp2000 is working like a charm, done a full diagnostic check and its thrown up a lot more faults than I expected but one thing is consistant between them all speed sensor not working so will get that changed if it ever stops raining. I saved the results to a memory slot in pp2000 but how do i export the results so I can read them without having to have all the gear connected, where does it actually save the results to? Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 26, 2015 No one know where pp2000 saves its results then? Ive had to take these screen shots as once i close the program i cant retrieve the information again despite me saving it several times now. Not really sure what all these faults represent apart from the speed sensor that i've already got but havent replaced yet. Car is a 206cc and multiplexed All systems that have flagged up codes have the speed sensor fault included. It might look simple and straight forward but its not, damm multiplex. Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted February 27, 2015 For help on those newer cars, I would suggest you ask at www.peugeotforums.com. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted February 27, 2015 Already have but they arent much help so far, must be because im new Share this post Link to post Share on other sites
