Ant*k 4 2 Cars Posted January 30, 2015 Hi all I have a 205 diesel the heater blowers work but does not seem to be getting hot, anyone know why? Thanks 1 Share this post Link to post Share on other sites
cheesegrater 43 1 Cars Posted January 30, 2015 Have you done anything to do with the coolant system lately? Share this post Link to post Share on other sites
jackherer 543 Posted January 30, 2015 Check the coolant level first of all! If that's OK the thermostat might be stuck open. Presumably it doesn't have a temp gauge? Share this post Link to post Share on other sites
hoodygoodwood 78 3 Cars Posted January 30, 2015 (edited) Sounds like a sludged up and blocked heater matrix . With the engine hot feel the 2 pipes going into the bulkhead , one will probably be hot and the other cooler as the water is not circulating .If you do change it break the old one apart and it will be full of rusty crud . As said check the coolant level first and bleed any air out . Edited January 30, 2015 by hoodygoodwood Share this post Link to post Share on other sites
