dobboy 231 2 Cars Posted January 22, 2015 Can someone give me a brief description of what i need to do to remove the reverse cable? Also what then happens to the bit on the gearstick for lifting into reverse? Does that then flap about? Could the cable be left in place if i wanted to, when going from BE1 to BE3 or VTS? TIA Share this post Link to post Share on other sites
dcc 855 Posted January 22, 2015 can leave the cable through the bulkhead. iic theres a grub screw on the gear stick base, you don't plug the cable into new gearbox, there should be a 'breather' there instead. if you fit it you wont get 3rd or 4th gear iirc I just removed the cable as it was easier. 2 Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted January 23, 2015 Thanks DCC, Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted January 30, 2015 DCC/anyone, if i remove the gaitor panel and the grub screw you mentioned, does the cable simply draw through into bay without taking centre console out? also, the lift up part of my stick, does that then slide about? can it be removed from the stick, from top with Gknob removed or bottom with stick removed? also, i am definately correct in thinking that a BE1 stick is ok to use with a BE3 box? Tia Share this post Link to post Share on other sites
welshpug 1,627 Posted January 30, 2015 You'll need to remove the rear part of the centre console and unbolt the top cover of the gearstick assembly, to swap the lift up mechanism for the plain black sleeve you need to remove the gearknob. its a roll pin not a grub screw. the stick is the same for BE1 and BE3. 1 Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted January 30, 2015 Thanks WP Share this post Link to post Share on other sites
S@m 156 Posted January 31, 2015 6 Months after i finished my last mi16 conversion (with VTS box) i still hadn't removed the lift up reverse cable, i tucked it up behind the expansion tank because i am exceptionally lazy, so fair play to you! With regards to the car side though, i prefer the be1 lift up reverse handle to the plain plastic tube that be3's have, given that its textured and moulded it just seems better to me whether or not you use it. Share this post Link to post Share on other sites
