jonb_5 6 Posted January 8, 2015 Hi, I just wanted to confirm a couple of things: Water temperature gauge, I have read this should be put in at the thermostat, can you just slide the sender in to the pipe and do the jubilee clip back up, I would have thought this may leak? There is a spare take-off on the SAD unit, would this be a suitable place? Oil pressure gauge, I am no longer using the oil temperature sender, just the oil pressure light switch. Could I remove the temp send and screw in hear instead of using 't' piece in the temp section? Thanks Jon Share this post Link to post Share on other sites
