ATK
Sill Drain Holes - Location
ATK
Got a wet driver side rear footwell. Under rear seat is dry as is everywhere else.
Think it might be coming from the lower seatbelt mounting bolt, indicating water in the sill.
I know there are 4 slot-type 'weep' gaps along the bit of the sill that hangs down/the bit you can see when looking at the side of the car from a way back.
Question is - are there any rubber-bunged sill holes (aside from the ones in the wheel arches) anywhere as I can't see any?
Juttie205
nope rubber bungs front and rear then the small slots on the underside these are more than likely blocked us a small flat screwdriver to clear.
ATK
Thanks mate. when you say "rubber bungs front and rear" do you mean the ones in the arches?
