idoari
What Is This Devices?
idoari
Hi,
i spotted under the dash near the steering columb two plastic cases.
one is a relay for sure what it is for?
IMG_1074_Copy.jpg​
another one with black box. what is is for?
another small question , where is the blinker flasher control located?
thanks
Ido
Black box is the central locking controller and the white box is the lights on buzzer
idoari
the passanger side front blinkers doesn't work and the bolbs are ok (i connect the connector directly to the battery and it works) .
do you know maybe where is thr blinker controller ( that tell the light to turn on and off) ?
MikeC
Check your earth around the light.
Check the hazard warning light (four way blinkers) switch, try wiggling it, if it has problems the direction indicators wont work.
idoari
that the weird thing the hazard works fine.
Weser
Sometimes if the hazard switch is faulty it can happen that the hazards work fine but the turn signals don't.
idoari
OK. will try to replace if i find one.
the problem is the car's right side works fine ( both rear side and front)
the left side one the rear works, the side and front doesn't.
Are you sure that it's not just a bad connection, earth or damaged wire?
Both the front and side repeater are fed from the same wire and connection.
If it's just one corner that's not working, it's unlikely to be the hazard switch or flasher relay IMO.
Weser
Ahh well if the rear one works then I doubt its the Hazard switch. Sounds like a wiring issue. As MikeC has said I would check your earths next to the radiator on the left side.
edit: Anthony got there first
Edited by Weser
if both indicator and side repeater are not working then it is likely to be the connection from main lighting loom to that particular side's indicator sub-loom.
plug will be behind the headlamp area, non side repearer cars dont have this piece of loom
mikeyd
try changing the bulb holder with the other one - had this problem and it was a faulty bulb holder
lagonda
Just to answer your original question...the flasher relay is with most of the other relays, on the drop-down fuse box accessed when you open the glovebox.
As others have stated, your particular problem is more likely to be a wiring/bad earth/bulbholder fault.
