stumpyjag
Gsf Head Gasket Set
stumpyjag
Hi all, would the head gasket set from Gsf include cam shaft seals as well as inlet, exhaust, cam cover etc. they have 33% off everything at the moment making the set around £23, bargain if it includes everything. I have already got original peugeot valve seals as I have heard bad things about non genuine.
Edited by stumpyjag
Kane
Not sure if the set will include what you're after but I'd recommend paying the extra and buying quality products i.e. payen
Headsets normally include everything bar a Headgasket but as said you pay for what you get
stumpyjag
Hi again
Head gasket set turned upto day with everything I wanted (cam shaft seals, inlet, outlet gasket etc much cheaper than buying separate) but also a head gasket as well. I wasn't expecting this and was intending to buy one from one of the usual manufacturerers. The manufacturer is BGA has anyone used these before, are they any good or would you still recommend buying one from payen etc
Thanks again
