erbs
Sloppy Giuseppe
erbs
when in any gear there is lots of play like stirring porridge
where is the best place to start looking for to sort this out as its really difficult to find gears
Rams_gti6
Gear rods, nylon will have worn out in the sockets, also the linkage bushes in the selector arm. Baker bushes and mounts do a uprated replacement that helps reduce play.
Edited by Rams_gti6
Check the two points where the gear rods are bolted to the subframe are still done up tight before you buy any parts.
As Jaskherer has said, worn linkages normally just mean the rods pop off, not give a sloppy change. The Ball joinb bolted to the subframe is the worst thing for this, so a new nut and washer fix's it or worst case a new joint, washer and nut (In my shop), The quadrant or 'L' linkage has a smaller effect on it but some new bronze bush's or std plastic ones which will last another 20 yr's for a couple of quid is the best option unless a Race car
erbs
well god darn it :blink: , had a look today and sure enough the ball joint on the sub frame was really loose, new washer and tightened back up,happy dayz
i do love free fixes :lol:
