James Cornell
Tough Nut!
James Cornell
Slightly unrelated I know, but is there a difference between the 1.6/1.9 driveshafts?
Guessing there is so I wanted to check.
I wanted to but two of these kits for my 1.9 but I am not sure
http://www.ebay.co.uk/itm/170933772663
Slo
Cheers tom ordered two
James they are different sizes, the 1.6 are staked and the 1.9 has an R clip
James Cornell
Should I be concerned that there was an r clip on the O/S with a retaining plate and not one on the N/S?
Or is it just common for the to go walk-abouts in the garage and people don't bother to replace them?
Edited by James Cornell
r clip and castellated cover is a 1.9 thing, though some aftermarket cv's have a staked nut on the 24mm threads, if they are r clip type with a missing clip that is technically an mot fail iirc! they can come loose even if they seem so tight they never would!
James Cornell
So it is possible that the N/S driveshaft has been replaced (120000 miles so I wouldn't be surprised) and the O/S is the original which is why it still has the r clip and the cover?
Mac Crash
Yip, more likely the wheel bearing has been replaced and the new nut came with the kit, I got 2 different nuts in my last wheel bearing kit, just re-used the original nut, cover and r-pin even though I've heard your meant to replace the nut every time it comes off, can't think why though?
not on the r-clipped type, only where staked.
Mac Crash
ah, ok, of course... that explains it
James Cornell
Well I am replacing both wheel bearings whilst the engine is out so I think I need to get on the bay for one of these castlated covers...
naah, breakers, forum or dealer.
James Cornell
Is that an offer welshpug :-)
i think i should have a few of them yes, I do keep them if I ever take a shaft or hub off in a breakers :D
ill have a rummage
James Cornell
Thanks mate!
James Cornell
Just took the N/S hub off and the spline is different, it has the two cut outs for the modern style bolts.
Thank you very much for having a look welshpug but I will not need the r clip and cap
