john-melbourne
What Parts To Replace?
john-melbourne
Hi Guys,
Now my engine is finally running, i want to keep everything in tip top shape, so with this in mind, i have a new oil filter, oil, plugs, fuel filter, radiator, coolant, timing belt, tensioner, auxiliary belt and water pump.
I am also going to be replacing the metal coolant pipe as mine as started to corrode, the radiator had seen better days hence why i have bought a replacement.
Is there anything else i should be looking at replacing at the same time, any sensors or switches?
John
If I was replacing every other part of the cooling system I would check the condition of the heater matrix.
Put a replacement thermostat on there while you're there if it's not been done recently that you're aware of - it's almost silly not to given how cheap they are whilst you've got the cooling system drained down to do the radiator.
QTH332K is the part number for a pattern 82 degree 'stat for an 1.6/1.9 8v or 1.9 Mi16.
john-melbourne
Re the hater matrix, does this look right, seems cheap?
http://www.carparts4less.co.uk/cp4l/c/Peugeot_205+Cabriolet_1.6_1988/p/car-parts/car-cooling-parts-and-car-heating/heating/heater-matrix/?214735000&1&e2afecacfb3dc8bf07f028fc1574a72feca5c536&000189
It says date from 08/90, but that's the one that's come up for my reg?
John
mrfirepro
second Ali, Hoses, the BBM OE set is well worth the money
john-melbourne
I better start saving then!
any idea on the matrix i posted above?
The CP4L / ECP heater matrix is a pattern one but it works well enough, and one that I fitted a few years back is still going strong despite enduring a massively over-pressurised cooling system for months(!) thanks to a couple of blown headgaskets by the subsequent owners.
Some people have said that the pipes didn't fit properly, but the couple that I've fitted have been a perfect fit.
scbond
To add to what Anthony said, I got mine from ECP a few momths back and it has been working perfectly fine.
As for other things to replace, I'd say inspect electrical connectors and replace any if necessary. When I was looking for a 205 I was determined to have a loom as it was when it left production...that didn't last very long at all!
john-melbourne
Thanks Guys,
Just wondered why that one was half the price of the other one.
John
john-melbourne
Does everyone replace the metal pipe with a stainless steel one, or buy the cheaper one from GSF?
John
The normal one is fine and will last a good few years, particularly on cars that aren't used throughout the winter months, but personally for the sake of a few quid I'd get the stainless one which should outlast the rest of the car.
john-melbourne
Hi Anthony,
Is that a pug part number?
John
scbond
  On 7/16/2014 at 9:10 PM, john-melbourne said:
Hi Anthony,
John
That's a part number for an aftermarket part. The Peugeot number is 1338.37.
