kenp
Ignition Switch
kenp
Anyone know if proper 205 ignition switches are available anywhere?
As stated elsewhere, the ones on Ebay are the wrong type with a 'X' fitting instead of a 'Y' where they connect to the barrel.
Our GTi is suffering from the old clicky-starter problem and everything points to the switch (immobiliser wiring looks OK). I'm dubious about going down the second-hand route since I imagine most switches are getting worn out by now.
Alternatively, does anyone know if the switch part from a later Pug (e.g 106/306 etc) would fit a 205 barrel (ignoring the plugs being wrong on the loom)?
Edited by kenp
Neat autos have them listed on ebay complete with the wiring (which they should all come with imo) so the X or Y part shouldn't be an issue, for £27.99 + £2.99 p&p.
g
kenp
Yep, seen that thanks but I'm trying to avoid having a different key for the ignition :)
It's the electrical side I want btw - not the mechanical switch barrel.
Edited by kenp
Mac Crash
I have the correct loom part and Y switch piece you require if your stuck, know what your talking about as I removed a complete ignition barrel and loom from a car weekend past plus have done my own car not so long ago when one of the factory solders failed.
kenp
You can replace the wiring on its own and keep your key.
http://www.ebay.co.uk/itm/IGNITION-SWITCH-CABLE-LEAD-FOR-PEUGEOT-205-309-AL-MODELS-NEW-/370543785357?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item564621758d
That's from neat autos as Graham pointed out.
Ahem...
Me earlier:
..which applies to the one you've linked to - look closely at the pic and you'll see it's an 'X' fitting :P
Edited by kenp
kenp
PM'd mate :)
