johniban
Radiator Set Up With Throttle Bodies On Gti6
johniban
I'm looking for radiator ideas for my 205 gti6 with jenvey throttle bodies.
I have seen someone use a civic ally rad to one side to give the trumpets room to breath but cant find who it was or any more pics, this is the route i wanted to use as it looked pretty smart and gave enough room for an oil cooler without loading everything in front of one an another.
i then though about lowering the rad by making up a new lower cross member to hold it, but didn't want it to look a bodge.
What have people done and do you have any pics?
Simes
Tilted and lowered rad using one of Tom's stainless brackets. See my rebuild thread.
stu8v
See my build pics. Link below.
std rad as low and far forward as it will go.
GilesW
John - this is what I've done. Works well and keeps a nice size rad.
What do you do about power steering (on a gti6 lump) with this set up? Presumably the pump has to be moved with throttle bodies? Will the pump fit where the a/c compressor was originally fitted on these engines, with one of Tom's brackets, for instance?
rallyeash
I used to run a Renault 5 rad which was to one side.
Probably what you were thinking of?
rallyeash
johniban
yes that was the one! looks pretty awesome!
rallyeash
It was 50mm thick so it cooled it perfect. I changed back to a Nissens 205 rad when I changed to dry sump.
johniban
what hoses did you use?
cheesegrater
I have a shortened rad that has a hole behind the thermostatic rad switch boss. It requires the tank being removed and welded. I may be persuaded to sell it cheap if you're interested.
kyepan
TRUMPETS!
i also have a shortened radtec rad to give clean airflow.
johniban
I don't want anything that needs repairing, cheers though
