jamie_1992 66 1 Cars Posted June 13, 2014 need some ideas on where to go next the cars a 1989 205 gti, the lights have always worked fine untill the other day i turned them on and nothing happened not evan the light on the dash iv checked fuses relays changed the stork where do i try next? Share this post Link to post Share on other sites
jackherer 543 Posted June 13, 2014 It's worth checking the earth on the front panel but I don't think that would explain the lack of dash light. The only time I ever had a similar problem was a mates 205 and it turned out to be a wire on one of the multiplugs on the rear of the fuseboard was loose. However it was because the car had been fitted with extra high wattage bulbs at some point in the past which had melted the connector. Share this post Link to post Share on other sites
jamie_1992 66 1 Cars Posted June 14, 2014 (edited) redone both earth blocks and looked over the fuse box and checked plugs still no lights where and what shall i start testing next also the rear side lights dont work but the brake lights do and the indicators also work Edited June 14, 2014 by jamie_1992 Share this post Link to post Share on other sites
jackherer 543 Posted June 14, 2014 You'll need to get a multimeter and check for voltage at various points, lights, stalk, fuse box etc and narrow it down that way. Share this post Link to post Share on other sites
jamie_1992 66 1 Cars Posted June 14, 2014 just put power into the back of the light (the top pin of the 3 pin plug) and both headlight come on aswell as rear side lights and light on the dash so they all work just need to find out why the stalk cant turn them on Share this post Link to post Share on other sites
jackherer 543 Posted June 14, 2014 OK so as you've already ruled the stalk out you know that power isn't getting to the stalk. You need to work backwards now, is there power at the fuse in the fusebox? If there is then there is a break in the wire between the fusebox and the stalk. Like I said you need to narrow it down until you find a break or bad contact. Share this post Link to post Share on other sites
jamie_1992 66 1 Cars Posted June 15, 2014 ok so there has been an improvement the lights now work although i did nothing to influence this they just started working again. so i have a dodgy connection somewhere but now trying to find it when they work is going to be even harder, so now im off to find somewhere that sells multimeter on a sunday. aslo when you have the lights on the n/s indicator dose not work but when you turn the lights off it dose, so looks like a day of testing for me today Share this post Link to post Share on other sites
