roccorich 16 Posted May 18, 2014 Does anyone know if the fuel sender seal is still available from pug? My car stinks like a petrol station. Cheers Rich. Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted May 18, 2014 Fairly common now for the hoses from the pump to be perished so have a nosey at those if you haven't already Share this post Link to post Share on other sites
roccorich 16 Posted May 18, 2014 They accessed from under the car? I know the sender seal is definitely gone as bits were hanging out. .. There's no leak as of yet just a lot of vapours do think its just the sender. 1 Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted May 18, 2014 (edited) Could be either or even a bit of both. Worth a check anyway. When you take the pump cap off you'll see the feed and return hoses. Then when looking underneath the car you'll see where they then join the steel lines. Edited May 18, 2014 by chipstick Share this post Link to post Share on other sites
roccorich 16 Posted May 18, 2014 Hoses look good. Just realised the seal I found sticking out in bits is the inner one for the sender if that makes sense. is that one avaliable and if so how do you seperate the inner and outer parts? Do I have to remove the whole sender first? Share this post Link to post Share on other sites
mhyphenl 10 1 Cars Posted May 20, 2014 Mines exactly the same, no sign on broken seal but the car stinks after short drive, don't think the problem is engine end as I've lifted the bonnet and no petrol smell but inside the car it's quite bad! It's worse when I open the windows, like the air is circulating and bringing with it the petrol smell! I can't see any sign if wet petrol but sender and pump seals could be the culprit, I renewed the fuel lines not long ago! Share this post Link to post Share on other sites
roccorich 16 Posted May 20, 2014 I took mine apart and cleaned up the mangled seal then smothered it in hylomar. seems okay so far. Share this post Link to post Share on other sites
