jack-da-stripper
Empty Engine Bay Pics
jack-da-stripper
looking for pics of a empty engine bay in particular around where the battery tray bolts on , looked in project builds but not to many clear ones of that area
while doing my restore it looks like my shell has had a bump at some point but unsure
regards - jack
Ryan
Can't remember whose car this is, but is this what you were looking for?
nick205
A couple here and I can take more if it helps...
Creased in the same place as mine nick, left hand chassis leg is over a bit!
nick205
I suspected it wasn't perfectly straight!
Any chance you could mark up my photo with where you think it's creased?
Just in front of the subframe mounting bracket, if you look at the picture Ryan posted its a flat surface, on yours (and mine) its a very slight ripple.
I think its only out by 10-15mm at the very front edge.
Edited by welshpug
nick205
Yup, can see it now.
Better check the sub frame mounting points and make sure they're straight!
nick205
Ta very much, measuring (and maybe bending) will commence!
jack-da-stripper
thanks guys , welsh and nick looking like I have the same little ripples you guys have :unsure: should I be worried ? , my subframe mounts up fine and have take basic measurements from round the engine bay and everything seems ok
cybernck
This is something that should get you worried :P
But it's fixable :).
jack-da-stripper
Holy crap ! Few hours in the repair I bet lol
jack-da-stripper
dale that's a stunner you have there , love topaz 205's :)
dale205mills
Thank you, I have got to get things moving on it again as it needs to be finished a driven, but I am lucky I have the silver 205 to drive :D​
