Wod
Xu10J2Te Turbo Questions
Wod
Hey I'm new here and have left the 106 Rallye and going with the 1900 205, now I got a question for you xu guys?
Is anyone familiar with the rgy/rgx engine?
To my understanding it uses a t25 turbo setup but it's own 3 stud fitment.
-Could a 4 bolt t25/8 flange be welded onto the cast manifold?
Secondly, if I wanted to increase the boost pressure could I tweak the wastegate actuator to retain the curve from the standard boost controller? Or would the ecu compensate this back to standard?
In the end I will get it chipped and mapped but for now I'd like to use just a boost and a:f gauges with adjustable fuel reg
wod
aarontrophy
i think a turbo technic manifold allows you to put a t28 turbo on,
