m@ttc
Block Sticker
m@ttc
in my service history it says it had an engine rebuild at 75,000 miles, i guess someones sprayed the ally block black? all i can make out is; the writing on the bottom says removed , and some type of scale like temp maybe?? just interested what its purpose was <_<
that'll say "void if removed" its a temperature indicator, usually found on cylinder heads.
m@ttc
so its like some sort of security on the rebuild warenty?
it records the hottest temp or somthing?
Edited by m@ttc
Daviewonder
Yes to prove it hasn't overheated.
m@ttc
it still could have overheated because of reasons which are the re builders fault?
Daviewonder
It could have, I dare say they'd look into that.
m@ttc
cool i understand now :D
I've got an Mi16 that was rebuilt by Matt @ QEP with a similar sticker on the head.
m@ttc
^^^ interesting,
Generally if overheated then warranty is voild, Bit worrying having those unless from a trusted source as the bottom end could be anything
