pyrrhic
1360Cc Tu3 High Idle
pyrrhic
I am not well versed on the TU3 engine management system on my winter beater 309 as I am with the one in my 205 CTI. The 309 right now has a high idle, I have looked for vacuum leaks but haven;t detected any. The car idles as high as 2000 rpm when cold, settles to 1500 rpm after warm. On a few times the idle will go down to 1000 rpm, and very rarely below that. Can someone help me get the idle back to normal?
trogboy
Hi,
Is this a single point injection engine, or a carburetted model?
Ad
Edited by trogboy
pyrrhic
I am fairly certain it is single point. I'll take a picture of the engine.
pyrrhic
I just verified it, the car has fuel injection, no carbs.
sickomotorsport
M.a.p sensor faulty or vacuum hose split? Check throttle cable isn't too tight
pyrrhic
I really need to educate myself on the TU3. This car has been dead reliable to me, only boring to drive, so I never really learned the ins and outs of the TU3. The XU5 on my CTI on the other hand... everyday I learn something new on that car! Where is the MAP sensor located on the TU3?
pyrrhic
OK, reading through the Haynes for this car, it says that idle speed is controlled by the idle speed motor and is non adjustable. Does that mean that perhaps the idle speed motor is bad? What controls the idle speed motor?
RossD
The ECU!
I would suspect an air leak before the expensive task of starting to swap out components. Make sure the SPi unit is tightened down onto the manifold properly and that the inlet manifold bolts on to the head are tight too.
The start checking all of the hoses coming off the manifold, including the one to the brake servo!
There were 3 types of injection fitted to these, Bosch A 2.2, Bosch MA 3.0 and Magneti-Marelli G6. If you can find out which one is fitted I might be able to help further :)
(Bosch A 2.2 had a distributor, whilst the others had coilpacks and no distributor)
Edited by RossD
