Rob_the_Sparky 10 Posted March 28, 2014 The housings are different styles, as are the new crimps. Has to be said though I've not looked at the original crimps, just assumed the new ones were the same, maybe that is why I can't find them! Going to be busy this weekend but will try to get into the garage and take a look. Crossed fingers that it might just become much easier Share this post Link to post Share on other sites
Anthony 1,003 Posted March 28, 2014 BTW I've got a vague memory of Citroen Xantias using the same sidelight bulb holder as a 205 but with a power timer connector, if that's right they would make a good replacement, power timers are sealed so should stay corrosion free for much longer. Ah, so that's where they're from! I've got a single 205 fitment side light bulb holder with a JPT connector in a box of random odds and sods but I wasn't sure what it was from. Another of lifes little mysteries solved Share this post Link to post Share on other sites
welshpug 1,721 Posted March 28, 2014 zx too, and S1 106's, got those on my 205. Share this post Link to post Share on other sites
jackherer 543 Posted March 28, 2014 Excellent, so they definitely fit 205s then? The Xantia part number is still available, 621532 £6.89 but Peugeot only list it for the 806 and Expert so it might be different to the 106 one. Share this post Link to post Share on other sites
jackherer 543 Posted March 28, 2014 I quickly looked up the 106 part number and it cross referenced to 205s amongst others? The ZX has two part numbers but they are the old style so I gave up Share this post Link to post Share on other sites
welshpug 1,721 Posted March 28, 2014 ah, many of the later side repeaters use them, but they aren't listed separately. looking at the part numbers 106 was the same as a 205 so you're right on that, ZX does use the old part number system, as it happens, they're going back to that system Share this post Link to post Share on other sites
A1AXX 26 2 Cars Posted November 6, 2017 Holy thread resurrection, I wasnt sure exactly what I needed as I'm doing a rewire. Mainly needed side repeaters and side light crimps. 6542.19 Available and ordered 20 (66p each) 6542.20 Available and ordered 10 (I think 80p each but I cant remember) 6542.22 is Available but on back order until Nov 15th, didn't bother as I may need to go back for more of the above Should get me started on the rewire I am removing the fuse board and wiring from a Rebel Loom Share this post Link to post Share on other sites
A1AXX 26 2 Cars Posted November 7, 2017 Got the little blighters, looks like the two part numbers 6542 19 and 6542 22 are the same crimp, just different size bag Share this post Link to post Share on other sites
jackherer 543 Posted November 7, 2017 They are similar but not identical, 6542.19 is for 1mm2 wire and 6542.22 is for 0.6mm2 wire, the parts that crimp the copper strands and the parts that crimp the insulation are slightly different sizes. Share this post Link to post Share on other sites
welshpug 1,721 Posted November 7, 2017 theyre for different gauge wire, one is for 0.6mm and one is for 1mm Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted November 16, 2017 LOL I still haven't replaced my sidelight connectors! This thread reminds me how long it has been since I've had time for the Pug Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 16, 2017 On 27/03/2014 at 6:05 PM, jackherer said: BTW I've got a vague memory of Citroen Xantias using the same sidelight bulb holder as a 205 but with a power timer connector, if that's right they would make a good replacement, power timers are sealed so should stay corrosion free for much longer. On 28/03/2014 at 2:48 PM, jackherer said: The Xantia part number is still available, 621532 £6.89 but Peugeot only list it for the 806 and Expert so it might be different to the 106 one. Did we ever confirm the Xantia jpt style connectors are a direct fit to the 205 oe / late side light connectors? I'm getting towards the end of my engine bay light loom refurb & these would be a better addition than the original plug so I'll get some of them on order if they are. g Share this post Link to post Share on other sites
jackherer 543 Posted November 18, 2017 I've been thinking about this again too but I haven't actually confirmed it. 621544 is another part number I have noted down to try, this is used on some quite late models so should be easy to get. There are some used ones on ebay - https://www.ebay.co.uk/itm/322606913992 - but new ones wont be much more than those. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 19, 2017 OK, I'll try to investigate further if they are suitable, I checked on service box & the 621532 are showing as NFP so an alternate is needed anyway. Fitted to various models including the 206 so could be found in a breakers yard. £7.98 each from pug so LCS are pretty good value. g Share this post Link to post Share on other sites
Cobalt_drill_bit 8 Posted October 14, 2018 Hi guys, I'm trying the link of the first posting: http://www.ryanmoore.comule.com/ I cannot access this site. Do people have this information otherwise? Best Regards, Maarten Share this post Link to post Share on other sites
jackherer 543 Posted October 14, 2018 (edited) http://ryanmoore.comule.com/ My saved link works, the only difference I can see is the lack of 'www' so the dns must have changed or something. Edit: I fixed the link in the first post. Edited October 14, 2018 by jackherer 1 Share this post Link to post Share on other sites
Cobalt_drill_bit 8 Posted October 14, 2018 (edited) On 3/24/2014 at 2:18 PM, Rob_the_Sparky said: Right, I have some contacts from Peugeot (6542.19) and they are not FASTON parts. Almost certainly some of the connections are FASTON as I can recognise the housings but the side light style connections are not (crimp is a very different type). Not yet found the range but given that some are from TE you might expect that the others are as well, some investigation to do. In digging about I have found this: http://www.te.com/catalog/pn/en/D03085-000?RQPN=AD-1522-1-CRMP-TL-PEUGEOT It lists some Peugeot/Citreon numbers and cross references them to manufacturer part numbers. Pretty sure they aren't 205 parts but might be useful to someone in the community. Hi, does someone have the PDF of the above link on their harddisk? Please PM me? Or a working link of course. Thanks Edited October 14, 2018 by Cobalt_drill_bit Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted October 15, 2018 Afraid not, I found that link using search tools and some educated search terms. Share this post Link to post Share on other sites
Ryan 99 Posted October 15, 2018 (edited) 21 hours ago, Cobalt_drill_bit said: Hi guys, I'm trying the link of the first posting: http://www.ryanmoore.comule.com/ I cannot access this site. Do people have this information otherwise? Best Regards, Maarten Take out the "www." part. It doesn't work with the www there as the hosting company wants me to pay extra to redirect www links to the correct page. It's annoying because sometime the forum seems to automatically put www on the start of URLs and it stops the link from working. http://ryanmoore.comule.com is the only URL that works. Edited October 15, 2018 by Ryan Share this post Link to post Share on other sites
Cobalt_drill_bit 8 Posted October 15, 2018 I can load the website now, no problem. Thanks Ryan for the effort to make this content. What you refer to as Misc Connectors is the TE Mark3 series. What tool do you use to remove these terminals from their housings? Share this post Link to post Share on other sites
Ryan 99 Posted October 15, 2018 I don't have a proper extraction tool. I found a small screwdriver that works. The terminals come out really easily with a bit of practice. You undo the clip at one end and then put something thin down the other end in between the terminal and the plastic housing - one side of the terminal has a small tab that folds in - then you can pull the terminals out. It's much easier to do that it is to describe... 1 Share this post Link to post Share on other sites
Stu_D 0 Posted June 8, 2020 On 10/15/2018 at 10:16 AM, Ryan said: Take out the "www." part. It doesn't work with the www there as the hosting company wants me to pay extra to redirect www links to the correct page. It's annoying because sometime the forum seems to automatically put www on the start of URLs and it stops the link from working. http://ryanmoore.comule.com is the only URL that works. Old thread resurrection! Ryan. The link to your website doesn't seem to be working again. Would you mind posting the information here? Share this post Link to post Share on other sites
Ryan 99 Posted June 9, 2020 I had to move it to another host earlier this week (long story), so for now it's at http://ryanmoore.byethost7.com At some point I'm going to clean it up and turn it into an article for the main 205gtidrivers webpage, but for now the address above should work. 1 1 Share this post Link to post Share on other sites
Stu_D 0 Posted June 11, 2020 On 6/9/2020 at 10:19 AM, Ryan said: I had to move it to another host earlier this week (long story), so for now it's at http://ryanmoore.byethost7.com At some point I'm going to clean it up and turn it into an article for the main 205gtidrivers webpage, but for now the address above should work. Thanks Ryan, very useful Share this post Link to post Share on other sites
Choppered 0 Posted July 16, 2025 (edited) On 3/3/2014 at 1:37 PM, Ryan said: Glad someone found it useful. It doesn't get a ton of hits (20-30 a month), but there's one person who's been looking at it 3 or 4 times a week since xmas. It's a shame Peugeot are so annoying about selling the parts only in bags of 4 or 5 for the plastic housings, and of 10 or 20 for the terminals. The prices aren't great, but if you could just buy what you wanted it wouldn't be too bad, but you end up having to buy five times more than you need and the prices really start adding up. If you could buy a single housing + terminals as a set for a couple of quid then they might actually sell any of them ever. I know this is an old thread now but wonder if anyone can help here. I've looked on the website but not on there. Im looking for the terminals than go in the fan switch plug they're very different to anything i've seen before and can seem to find anything online. anyone shed any light on a part number?? Edited July 16, 2025 by Choppered Share this post Link to post Share on other sites
