Daryl1205
Gti6 205 Problems
Daryl1205
Right my 205 has had starting problems since I got it iv now put the gti6 engine in and it ran almost fine when I first done the conversion then the cam shaft pulleys went so had to rebuild the head only things that changed is the type of pulleys and the flywheel iv had it running but coz I never had gear oil or the power steering hoses on I shut it off but it was running without throttle but now it only fires when you launch break cleaner down the intake I know it's over fueling
Any idea of anything that can make this happen the pump does run and the injectors were injecting but dono if there still doing so
Thanks Daryl
dcc
Fuel hoses wrong way. Dead fpr. Sliped a tooth. Cam sensor. Tdc sensor. Knock sensor. Icv. Fuel pump. Erm basically do a search :)
Daryl1205
Got it going now got a new problem this is me on my 4th fuel pump in 2 years and iv not done 4000miles with the cars after buying it
So now looking for a fuel pump loom as it's wired right into the ignition and keeps burning them out any one got one
Thanks daryl
Low voltage can burn out fuel pumps, check the ground connection in the boot behind the rear left tail light
Spiky
I might had a loom you can use
My loom was used my twin pump setup, the OE feed to pump turns on he relay which in turns enables a new feed direct off he battery
So you will have to a little but if re wiring
You may have a bad wire somewhere, and the drain is killing it
