arnold80 4 Posted December 22, 2013 Quick question! I'm unfamiliar with the bodywork side of things when it comes to cars but I'll try my hand at anything. I'm about to undertake, from what I've read, the long and tedious task of stripping all the underseal from my car. I have read through lots of threads on the subject to familiarise myself with the process. I was wondering if i would be better to get it to at least a primed stage in sections? i.e. boot floor area then tank area, working my way forward, therefore reducing the time the bare metal will be exposed. The reason I say this is I might get so muched stripped then not get back too the car for a few of weeks. Share this post Link to post Share on other sites
rikky 37 Posted December 23, 2013 I'd prime whatever you're got down to bare metal as a matter or urgency whenever you do it to be honest. Whether you do it all in one day or a square foot a month, I wouldn't leave any of it open to moisture etc Share this post Link to post Share on other sites
welshpug 1,626 Posted December 23, 2013 Theres paint on the steel under the sealant, unless its a rusty area where the sealer is lifting already, though as mentioned, get some etch primer and a solid colour straight on there. You can always rub the paint down again quickly if needed, primer is porous dont forget. Share this post Link to post Share on other sites
arnold80 4 Posted December 26, 2013 Thanks for the replies! Didn't know that about the etch primer, will get some solid colour aswell! Share this post Link to post Share on other sites
stu8v 68 1 Cars Posted December 26, 2013 Red oxide primer, then stone chip, then body colour was my choice. It should give it a fighting chance. Share this post Link to post Share on other sites
arnold80 4 Posted December 26, 2013 Getting stonecipped at a mates garage stu, so just need something on it to protect the bare metal for the time being. Share this post Link to post Share on other sites
mowflow 67 Posted January 3, 2014 I did the rear half of the car in 1 go but it took me a few months as there was some cutting and welding to be done (and I couldn't weld when I started). It was during the summer and the car was garage but I still got some flash rusting. I had to clean it all again with a wire brush before priming. I've used jotum epoxy mastic. It's used for steel hulled boats so should do the trick. I'm currently doing the front but learned from my mistake and just cleaned the areas that needed repairs. With those done I gave them a quick coat of primer and have now went onto removing all the other stuff. It's a job that takes ages. Especially if you are doing it as a hobby rather than a job and only so much can be done at a time if the car is on stands rather than a lift. Share this post Link to post Share on other sites
