NFS
Xu10 J2Te Cut Out And Not Starting
NFS
Dont know the AA man tested it, im useless with electric.
NFS
Does anyone know what these two green wires could be? could they be for the keypad? if so that would explain why they are soilded together and infact is not my issue.
TELL US WHAT THEY ARE CONNECTED TO!!!
Slo
They wont be, or weren't rather, connected to the theoretical keypad. The only reason i can think of for this kind of bodge is to hard wire the fuel pump that the ECU controls!!!!!!!!!. SO..........
As above you need to tell us which pins they are connected to.
NFS
Looks like its pin 3 on the brown plug
NFS
I cannot find where it goes. It gives a reading on both wires when I put it on pin 3
Slo
pin 3 should be switched live from the ignition it should also be linked to pin 27 on the ecu. so trace those green wires to the ecu plug and see
Edited by Slo
NFS
DD16DB51-DA17-43E0-AE1A-97E7C6BC0835-596
This is the pin that is on the other end of the two soldered wires
NFS
What are they for?
depends which pin that is.
both wires wont be going there, so you need to carry on buzzing through till you find where else it goes.
Slo
Well thats the right pin alright so im making a guess that the other wire that you cant trace goes to pin 1 or 9 on the double relay plug
NFS
I checked all the ecu pins and that was the only one that registered. Does anyone have a pinout for this ecu so I can see if rejoining these wires will fix my problems
NFS
So what are these wires for?
as in look elsewhere on the engine loom, not the ecu plug.
look at the links on page 1.
Slo
Hmm someone has made a right pig in a poke there but theres a diagram on this page how it should be wired up.
NFS
It goes to this plug that is next to thee ecu
09A5AAED-C9C3-4857-96A8-3E94448C9D20-600
Slo
What does the other wire that's soldered to the other one that goes to the ecu pin 27?
Looks like an ignition amp extension connector to me
Edited by Slo
NFS
The two picture I posted are where both wires terminate. According to my MM
Slo
So your saying pin 27 on your ecu is wired to the middle pin on that connector through those soldered up wires?
NFS
Yeah twhy?
Slo
Can you pull back the rubber to see if its got any number on the wires of that connector.
Whats it connect to?
I've got a turbo wiring loom out in front of me right now to compare too.
Edited by Slo
NFS
Thank for your help guys. Real credit to the forum!
I put the loom back in and have now got it running again. I didn't connect those green wires and have insulated them. It's running now however it's not very smooth to drive like it might be down on power abit juddery on light throttle load. Any ideas?
