stu8v
Whats It Worth Thread?
stu8v
What do you guys think?
Its not a for sale thread just need some guidance for insurance etc and as its took 3 years on and off I've kinda lost track of the build costs LOL
I'm sure I will have forgotten some stuff but here's most of the spec.......
As it stands its not yet turned a wheel on track, that will be next year :-)
1989 (G) 205 GTi Track Car
Non Sunroof Shell
Stripped, Strengthened and Lightened Shell
Full Weld-in Cage through to strut tops
Strengthening Gussets
Radiator Lowered and Moved Forward
Lexan Windows all-round
Internal Fuel lines and Brake lines
Uprated Master Cylinder
Adjustable Brake Bias
Auto Bonnet
Magnum Composite Side Mount Seats
TRS Harnesses
DTA S40 Management
Bespoke Engine Loom
Lightweight Car Loom
Lightweight Gel Battery
FIA Cut-Offs
Shift Light
Launch Control Available
23mm Rear Torsion Bars
25mm Antiroll Bar
Fully Refurbed Beam - New Shafts/Bearings/Seals etc etc
ZX Rear Trailing Arms (more track orientated camber and toe)
Grp A Solid Type Mounting Kit
Tarmac Bilsteins
Braided Rear Brake Lines into car
Front Gaz Coilovers
KAD Adjustable Billet Top-Mounts
Braided front Brake Lines
309GTi Front Arms
New Old Stock Genuine Peugeot 309 Shafts
GTi6 Front Brakes
Vts/GTi6 Engine (FSH and 75k)
New Cambelt/Pump/Tensioners/belt
Lotus Throttlebodies
Bespoke Inlet Manifold
Fabricated Stainless 2.25" Exhaust System
Vts/GTi6 Exhaust Manifold
Uprated Engine Mounts
Oil Cooler
1.6 be3 Box (short box)
Quaife Diff
Quickshift Fitted Along With Some Rose Joints
Uprated Gearbox Mount
Fabricated Alloy Breather Tank
Its Road Legal Still.....
Oh and importantly its a Rust Free Shell!!!
What are you wanting - the value of the car if you were to sell it, or the value to get another 205 and rebuild it to the same spec? Very different prices...
14PUG
Is it MSA log booked? In date seats / harnesses. Plumed fire extinguisher?
stu8v
Just to replace it, really.
Just the eats are out of date, not logbooked
stuart
I'd say around £5-6k maybe? Or probably more to replace like for like
Edited by stuart
