jacob_williams
Peugeot 205 Dturbo Revving Up By Itself
jacob_williams
hi my Dturbo 205 has just started to revving up by itself, it drives fine, but as soon as it as you pull up to stop it will rev up by itself and pour out white/blue smoke also when it does this, it will take 2/3 seconds to turn off. i have been told it could be the turbo, but have been checking the engine oil every morning it and it doesn't seem to be getting through any oil. I have noticed that there is quite a few small air bubble in the fuel line, not sure if this is normal? any help would be much appriciated cheers Jacob
TooMany2cvs
Because diesels are controlled by restricting fuel rather than air, it's gotta be either fuel or oil getting in.
It may just be a leaky injector. I'd investigate sooner rather than later - if it is the turbo seals, then one day it may well just carry on running away. Since the "fuel" is then uncontrolled, even taking the key out won't stop it. Nothing will, until it runs out of "fuel"... Which, of course, it'll do at full revs. And since that "fuel" is the sump contents...
AIUI, standard main dealer procedure to deal with one is just to evacuate the workshop and wait for it to go bang.
If it's running on its own oil via the turbo stop running it at all until it is fixed, do a search on youtube or somewhere for runaway diesel to see why.
indeed, it could be quite catastrophic.
however it could also be an air leak, my brothers old 306dturbo would rev up a little when running very low on fuel (i.e on the verge of cutting out)
Would an air leak "pour out white/blue smoke"?
I'm not sure, depends on the definition of "pour out".
TooMany2cvs
It's the "take 2 or 3 seconds to turn off" that's scaring me...
Paul_13
Sounds like the turbo seals are about to go. It'll really go and runaway, then you're screwed
Pop the intake hose off and check if there is excess amounts of oil
Edited by Paul_13
jacob_williams
The car has been sitting off the road for 3 years until last week so there is a good chance the seals on the turbo have gone. Have been thinking about putting the the 1.9 td engine from a 306 in it so i will probably do that if i can find an engine. Also there is a 2.1 td engine but can't seem to find much info on that.
TooMany2cvs
12v. Most of 'em will be out of XMs. A few late Xants & 406s, and the odd 605, too.
jacob_williams
Can't seem to find that many people who have put that engine in a 205, is it a simple swap.
Edited by jacob_williams
relatively, but its a hefty lump and there are clearance issues.
ORB
We used to get Saab 9-3 180's regularly running on the sump oil. I blew one up on the M6 that was only days old
jacob_williams
Im am trying not to use the car any more started losing power now, if it wouldn't stop could you not just stall it?
ORB
You can fight it with the brakes. But sometimes it's not that easy
jacob_williams
Will have to phone up a few scrapyards tommorow and see how much i can get an engine for. thanks for all the help
