johniban
Gti6 Clutch
johniban
has anyone got the part number for a standard valeo gti6/xsara vts clutch kit? i want to order one from euro car parts but there is a choice of two
If there is two i can only imagine one is a cheap tat transmech one and the better is valeo/luk
Though most will use the 1.9 mi/bx16v push clutch.
johniban
im using the standard vts box not sue what clutch i need really, id prefer a push clutch if i could fit one.
theres a choice of two valeo
Change the clutch arm to a push type, job done.
S@m
Vts pull clutch p/n is 2050s9, i use one on my mi16.
Edited by Sam306
johniban
Will the clutch arm from the 1.9 box fit? id love to use a push clutch they are so much more less hassel! but then i dont know what clutch i need, what can i type it on euro car parts to find a push type clutch?
just look up a citroen bx 16v?
yes, fit the complete kit from your BE3 push clutch gearbox (cross-shaft/fork, arm, matching bushes i.e if they are white fit white, yellow fit yellow.)
buy a bx 16v clutch, job done.
standard be3 cable, no faffing.
that link doesn't point to anything specific.
Edited by welshpug
johniban
i know it doesnt that is the problem there is a choice of clutches i dont no witch one to go for
YOU have to decide, all the options are there plain as day!
dcc
I used a standard GTI6 clutch on my 8v XU, with a mi16 pressure plate and a be3 release bearing, this is all for a be4 gearbox from a xsara vts. hope this helps.
Edited by dcc
johniban
what i was asking is that there was a choice of diffrent clutches on euro car parts, two of the same make, in the end i went for an luk clutch as it was a decent price and they are pretty good clutches and there was only one to choose from
But now i have trouble as ive tried to swap over the parts from the gti box to the vts box and i cant get the pin out the gti box :/
