Dylan l 0 Posted October 12, 2013 Last week I took the car out for a spin and after parking it up no problems. A couple of hours later noticed a pool of gearbox oil had escaped. I have taken the gearbox out and found a hole in the diff housing. We have looked at all of the gearbox and it seems there is nothing missing, but something has broken and ended up in the final drive and punching it's way out of the gearbox. Is there any thing in the tran x lsd to break up? as I am yet to send it back. Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted October 12, 2013 The Tranx planet wheels can break, as I've broken some. If I were you I'd strip the diff to see what's what. Tranx as such are no more now in any case, but when I sent mine back they tried to charge me £40+VAT to strip it even though I sent it already in bits. Share this post Link to post Share on other sites
Dylan l 0 Posted October 12, 2013 (edited) robbing bar stewards will look in the diff tomorrow. Tran x website show they have moved from but do still do a service, but it does say Tran x powered by Quaife. Edited October 12, 2013 by Dylan l Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted October 12, 2013 Do '3j driveline' do the old tran-x stuff now then? I'm guessing miles can enlighten us. As Tom says get it stripped to rule it out, it's a fairly simple task stripping and rebuilding them. Share this post Link to post Share on other sites
Rippthrough 98 Posted October 12, 2013 Quaiffe do the Tran-x parts, 3J is the new company from the MD at tran-X Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 12, 2013 I heard that it was 6 to 8 weeks for a plate set the other day from someone so it could be a while, I doubt 3j would service (Never know what the contract was) them but its worth asking. One reason why I changed my Diff over as I don't like dealing with Quaife Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted October 12, 2013 Either way, don't let them rip you off for £52+VAT (TranX website) to strip and rebuild an LSD. It is 8 bolts to get it in bits! Share this post Link to post Share on other sites
Dylan l 0 Posted October 13, 2013 Had a look at the diff today and there are only 7 13mm bolt heads and 8 holes and we found the bolt head. It does seem that the diff is still scrap as a lot of the threaded holes are munched. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted October 13, 2013 Had a look at the diff today and there are only 7 13mm bolt heads and 8 holes and we found the bolt head. It does seem that the diff is still scrap as a lot of the threaded holes are munched. Get some pictures up, I'm sure it can be repaired. Or I'll give you a fiver for it Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted October 13, 2013 I'll bid £10 and a bag of sweets! As Allan says it should be repairable. Either clock the cover round and drill/tap 8 new holes, or drill and helicoil the holes that are there. 1 Share this post Link to post Share on other sites
Crescent205 11 1 Cars Posted October 13, 2013 i had the same last week as i was getting the car ready for a rally i noticed a hole in the diff casing, Turns out that a bolt from the diff (not the crown wheel) had come out and worn a hole. simply got a new bolt and locktite them all in. obviously replacing the cover. Share this post Link to post Share on other sites
