NFS 32 Posted September 30, 2013 Hi Guys, im just putting my 205 back together and im stuggling to get the top door weather stip stick on properly, what have people used to stick them neatly? ps thanks for the pic macaroni Share this post Link to post Share on other sites
NFS 32 Posted October 2, 2013 Any ideas guys there have been plenty of repainted cars on here. Share this post Link to post Share on other sites
Simon a 5 1 Cars Posted October 4, 2013 I used double sided foam tape and some new plastic clips Share this post Link to post Share on other sites
2052006 10 Posted October 7, 2013 I'd be interested to know what's best to use too. When I took mine off a few weeks ago, it seemed to be stuck on with some sort of (very sticky) tape, most of which is still stuck to the metal. Simon, can you provide a link to the type of tape you used? Share this post Link to post Share on other sites
DamirGTI 323 Posted October 7, 2013 Ditto .. double sided tape , myself i used 3M (a bit pricey per roll , but much better adhesion quality than other cheaper unbranded tapes ..) and OE clips . Need to clean the surfaces thoroughly (both the weather strip and the area on the bodywork , i used 99% Acetone) then heat up the area on the bodywork with an industrial fan , heat the side of the tape to be taped on the body a bit as well .. tape it on the body whilst the surface is still warm , heat again this time the tape side to be taped on the weather strip and tape up the weather strip onto the tape .. fit clips and that's it . D Share this post Link to post Share on other sites
2052006 10 Posted October 7, 2013 Useful, thanks. By clips, I assume you mean the ones in the top corner ie. one clip per side? Iirc, there are no more? I was planning on reusing both of mine, I assume I can? Share this post Link to post Share on other sites
Simon a 5 1 Cars Posted October 7, 2013 No there's about 4 each side, they are the type with the pin down the middle, they are pence to buy from dealers, tape I used came from a bodyshop suppliers, I just asked for some tape for trims and they advised which was best to use Share this post Link to post Share on other sites
