A1AXX
1.9 Gti Subframe Into Phase 1 Base Model
A1AXX
Hi,
I have a 205 gti subframe in my cj, and I'm converting the new base model to gti subframe.
When I looked closer the phase one subframe mounts differently at the front to the 1.9 gti one that bolts straight up to the chassis leg. The phase one has a bracket and a thread going down through the subframe.
Is this a problem? I want to know if the 1.9 subframe will fit or will I have to modify the mounting point?
Josh
A1AXX
Found the answer on here.
For anyone interested it makes no difference and you can put a 1.9 subframe straight onto the base model chassis with the different mounts!
