Paul_13
[Engine_Work] Puff The Magic Dervgon
Paul_13
Here's the story of my 5 door derv runabout.
Pretty much been in the family since new with only 1 additional owner but my Dad bought it back off him.
Originally started with the lovely beige interior which was quickly disposed off!
At an early age of ownership the front running gear was swapped to 1.9 gti running gear, which proves to be one hell of a lot more stable than base model!
I also swapped the front brake calipers to 1.9 gti items as the 1.6 brakes had given up the ghost and when the pad locking bar went walkies on the way to driving to work in Brighton it was time for their farewell!
Paul_13
Out with old
(NA 1.8 D with 182k on the clock and still going strong!)
Paul_13
Some very perished fuel lines
Lovely veggie goodness!
Don't any pictures of the new engine installed, but basically the specs are:
1.9 Dturbo engine out of a 405, Bosch pump :) T2 turbo and I believe possibly a Hdi box.
Here's a pic of halway through the gov mod:This basically replaces a spring on the cradle which limits the fuel delivery over certain rpm. Most people shim them but Ryan had put a stiffer spring in and I was basically the guinea pig of his modification :lol: It's worked well! Full on fuel all through the rev range.
Next was the LDA pin modification (boost pin)
New ground down version vs. old
Where it came from
Paul_13
The spindle was adjusted so there was more travel on the throttle and because of this I needed more travel on the pedal, so a quick modification was needed!
Excuse the bodged boost hose! Also bent the accelerator pedal to gain more travel!
The air filter I had on there was a bit restrictive
Thought I could smell a burning smell! This was resting on the turbo
Paul_13
The plan was to use this front mount intercooler off a BMW e94
Paul_13
Had a bit of a hiccup when I decided to tighten the wastegate arm on the actuator. I'd manage to flatten the thread on the arm.
So I had to take the actuator off and take it to work to fix it. I ended cutting the flattened part off and threading the "eyelet" back on which means the wastegate will be firmly closed all of the time and resulted in 31 psi of boost through the poor turbo when I turned up the fuel up!
Needless to say it felt rather rapid at this point, only downside is the top mount interwarmer was hot enough to fry an egg on! (As i had not fitted the front mount)
I sourced a fmic adapter as the sale of the Xantia manifold fell through :(
Next modification was to get rid of the restrictive fuel filter setup and increase the banjo size.
Ordered a 10mm banjo off ebay and a 10mm fuel filter.
My reason for doing this is the inlet hose to the bosch pump is around 7mm in diameter and if you are running veg oil becomes a bit restrcitive.
Off came the fuel filter housing
The new fuel filter and banjo setup
The difference is night and day, it doesnt feel strangled up the rev range and pulls considerably better!
Edited by Paul_13
Gman
Looking good Paul, looking forward to going for a ride in it when you next bring it over.
aldworth33
We've got a van at work with one of these workhorses in I think, might start having a play as it's pretty soggy top end. Looking good tho mate can't beat cheap DIY performance mods
Uberderv
Looks good, how easy was it to get the top of the pump back on after the gov mod? I think your fuel filter might be on the small side though, also the filter heats the oil through the metal swirly bit.
Paul_13
A little bit tricky, you just have to wind the fuel screw out fully then it makes life a lot easier!
It's the only filter I can find that has 10mm connections on.
A few people use the audi tt filter but it only had 8mm connections.
But compared to the previous setup the fuel filter is more than adequate!
I haven't noticed a difference in the mornings yet. If I'm moving it's not a problem.
I think there's a lot of myths surrounding diesel tuning on XUD's
Edited by Paul_13
Paul_13
I thought i'd get rid of the plastic pipe which feeds the intake of the turbo and replace it with a less restrictive setup (eventually)
I bought a reducer 90' bend off of Ebay and a bit of flexi hose and an air filter. Excuse the long flexi hose it's a temporary measure while I get the FMIC sorted.
My rad lowering bracket, a piece of 20 x 40mm unistrut from work with a couple of 90' cleats and some 12mm bolts and nordlocks.
Edited by Paul_13
Paul_13
15" steelies which look awesome!
But came off a day later as they rubbed soo bad
Paul_13
Lowered the rad and makes a huge difference to the inlet temps , I can actually put my hand on the intercooler after a sprinted drive and not burn my hand! Bought some slim line fans off of ebay and they've done the job nicely!
Next I moved onto mocking up the BMW front mount, now if I had a GTI valance fitted it wouldn't be a problem! But because I'm trying to fit everything behind a base model valance, it's a task and a half!
I don't think the police at work would appreciate this!
Edited by Paul_13
Paul_13
After deciding that the BMW would not fit I opted to go for a universal cooler
universal-x-small-fmic-bar-plate-design-
I couldn't find another that fitted comfortably, but this one will do the job the adequately!
Paul_13
Plus a few silicone hoses off eBay I have a front mount which will fit!
chipstick
What you need is a genuine Peugeot roof rack which I happen to have for a 5 door ;)
Paul_13
I'm ok, have thought about it a few times as I knew you had one. Out of interest where does it fix to?
chipstick
Grips up under the roof at the top of the door shut and clamps down on rubber feet on top.
Paul_13
Bit of an update for you diesel loving fans:
I bought a random filter from the local motor factors. It's only 8mm connections and I wasn't too pleased with this. I've been after a 10mm inline filter and have really struggled to find one until now. http://www.inlinefilters.co.uk/Filters-Fuel/Inline/Metal/FFG-FF5079 Got a few of these on order now
A few bits turned up in the post:
Here's a quick mockup of the front mount setup
And pretty much installed:
Just to see what it's like unfiltered!
Grille sticks out a bit, got a bit of chopping to do!
Paul_13
And a hint of whats going on next!
BuisEwBWkKGrHqJigEv1z5ktBMwBbHNQ_3_zpsf4
kyepan
this is all kinds of cool!
i want to see a photo with puff making a cloud of derv
Paul_13
Let's say I'm looking forward to a nice crisp cold morning!
Dundy53
Proper stealthy, I like it!
Paul_13
Was like a rocket on the way home earlier!
I found a 10mm filter at last!
Works a treat!
Paul_13
Might have to have a passenger taking a photo :lol:
You won't be able to see much :ph34r:
It's strangely addictive! Diesel tuning that is. Got the xsara quick rack going on at the weekend!
