omri617
Nfx Engine - 106 Problem
omri617
Hi
I'm trying to help a friend with a problem with NFX engine.
His car runs fine till the engine temp gets to 69 .from 69 to 90 , the engine chokes .
Map sensor changed - no change.
Temp sensor changed - no change
ECU changed - no change
What can it be??
lambda sensor is likely as it is not used until it has warmed up.
Edited by welshpug
