onur205gti
N/a 8V Max Performance...?
onur205gti
Race Car
nickname : Drill 205
car parts :
mi16 block
cylinder head oem 8v
306 gti 86mm pistons
605 2.1 diesel crank
143mm arms 1.9 gti
custom shirt
pipercams kits
ss headers
45mm itb
650cc injektörs
microsquart v2
short shift
aem wideband
PPR MOTOSPORT cylinder head raceport-oversize valve
engine compression 13.8cr
e85 fuel
How do you think the engine life and power?
Vili
192hp/235Nm, but won't start because OE starter doesn't have enough power.
onur205gti
colombo 286 cams 11.6 cr dyno
race port not
itb not
310cc injektör
528252_575323742485587_653701729_n.jpg​
Edited by onur205gti
onur205gti
Do you have an example made ​​of car?
dcc
there is a 200+ bhp 8v which revs to 10k somewhere on youtube - pretty sure henry yorke took the video so he might know.,
onur205gti
yes watched..
target: 200+bhp 800kg I think race is used for
2.gear 60 kmh start 200kmh finish
rallyeash
Mass engine for sale on pistons heads 200+ na 8v.
dcc
Iirc its a 1.8 too
onur205gti
do not skimp on thank you..
Iirc its a 1.8 too
Do you speak more descriptive?
I know a foreign language at
The spring tester looks like bathroom scales! I guess it could work.
onur205gti
PPR Engineering 1.8T Intake Manifold
before/after flow bench & dyno test...
28psi boost → 470hp (oem Aug intake manifold)
25psi boost → 500hp (PPR Engineering Aug intake manifold)
531717_513781801993211_1483223304_n.jpg​
s2000 before after.. dyno dynomics
481463_481719941866064_83940651_n.jpg​
onur205gti
ppr motosport 205 gti race port
1150401_642641379087156_116840595_n.jpg​
allanallen
1150401_642641379087156_116840595_n.jpgâ
Christ! There's nothing left
DamirGTI
... and the key area for making 8v head flow better isn't the inlet port entry at all (most of the heads actually) , if this is all the work that's been done to it it'll be worse than OE . It will "flow" better , but only when measuring flow without valve fitted .
Simply put , bigger isn't better , in the case of this head certainly not.. and i know that port guys like to "modify" heads like this - it's the easiest area to tackle , and it has looks , which always picks up the owner excitement upon inspection .
It's a tricky head to port/flow properly .
D
jack-da-stripper
what was the spec and final output of the engine ? very keen to know because I have a massive soft spot for the old 8v's :)
must admit was very surprised to see standard inlet mani on that head lol :P
Edited by jack-da-stripper
dcc
Damir I am a bit intrigued by your comments. Why would Dave Baker (he who shall not be named) (aka puma racing) have spent such a vast amount of his time drilling the benefits of the larger valves? He also had back to back print outs to prove it.
allanallen
Damir is on about the huge port entry, he's not even mentioned valve sizes
have a look at Wardy18's engine.
DamirGTI
Myself , i'm on the route that this head has big enough valves as a stock item , with good head porting job it simply doesn't need bigger valves .. some of the reputable engine builders also proved this by actually testing the head on a FB with/without bigger valves and found that it doesn't gain noticeable improvement in head flow capabilities . Plus you need to reshape the port throats after fitting bigger valves , cos it wont work just by fitting bigger valves themselves .
Reshaping/modifying stock valves is better idea , and making good angle seats .
As for Mr. DB experiences , i'd rather not comment about .
Each to his own i guess .
D
jack-da-stripper
just watched a few videos on youtube :o < was the facial expression lol , that thing is insane
GLPoomobile
I think if you were to briefly summarise what DB liked to preach, it was that in his opinion bigger valves were better on the flowbench. He seemed to be all about the mathematics and the theory rather than the real world results. Lots of hot air (tee hee) but where were all these world beating engines that he claimed to have built? Of course, were he here now to speak for himself, he would have been furious at me making such a statement, for he did not like to be misquoted or misunderstood.
On the flipside, Sandy has spoken about bigger valves and pointed out that it's not all about outright flow on the flow bench. There's gas velocity (or something along those lines) to consider too. But then what would Sandy know? It's not like he's actually built any decent race engines, has he? LOL
Edited by GLPoomobile
DamirGTI
In my opinion , valve size certainly isn't the issue which "robs performance" of the 1.6/1.9 8v heads , nor does it needs larger ones to breathe better . Especially for road car which needs good low/mid range performance ideally without dead spots in rev range , if its an race car/engine , larger valves would be of benefit if done properly (ported head , valve pockets reshaped , unmasking the valves , cam profile etc.) and it'll mostly start to work/feel on the upper rev range till the limiter thus the mid/low rev range will suffer a certain degree . (do correct me if i'm wrong)
Valves (inlet) , as i've researched (i do not have an FB) "penny on a stick" shape works best for this head , PTS and Longman's aside from standard ones .
The main concern to me points out to the quadrant inlet port shape (hence XU10 flows better) , which then blends into a throat . Air as such doesn't like changes of the port wall shapes , quadrant port shape increases surface drag and in the end causes turbulence's which are common issue inside this heads and that upsets flow and air/fuel mixture quality badly . So , the approach in modifying this head is in such way to minimize turbulence by reshaping the insides of the ports/valve pockets aiming to create as much swirl as possible .
Interesting thing is that the head gains flow quite a bit when an deflector is positioned on the port floor - will try material adding next time and see what happens .
D
Edited by DamirGTI
Yes, big, open ports are certainly not consistent with current trends in high velocity ports. It would be interesting to see some port flow charts @ 28in.
