Alan_M 66 1 Cars Posted August 4, 2013 Looking at going halves with a workmate on a press. Found this on Amazon. A hub and trailing arm shaft will fit it. Trying to think of a reason not too, apart from it's cheaper to run any jobs up the garage and handover £20. (I've got a front set of bearings to do for the 306 and 205 & rear shafts on the 205, so the press is really only costing me an extra £40). Share this post Link to post Share on other sites
shonkers 6 Posted August 4, 2013 will save you a lot of hassle in the long run instead of big hammer Share this post Link to post Share on other sites
welshpug 1,737 Posted August 4, 2013 personally I'd hang fire for a machinemart vat free day, much easier if you had any warranty issues, and it'd be cheaper again, for exactly the same press. http://www.machinemart.co.uk/shop/product/details/sealey-yk10b-10-tonne-bench-press?da=1&TC=SRC-press if you are going to buy one I'd consider a floor press, as in reality they wont take up any more space and could be more useful. http://www.machinemart.co.uk/shop/product/details/sealey-yk10f-10-tonne-floor-press?da=1&TC=SRC-press Share this post Link to post Share on other sites
Ryan 99 Posted August 4, 2013 My friend has one of those presses (bought from ebay for about £150 a few years ago). It's a perfectly good press for 205 work, but if you plan on putting anything big into them then there's only about 60cm between the uprights and that can make manoeuvring things into the right place difficult. It was too small to press the bushes out of a 200SX subframe for example. Share this post Link to post Share on other sites
Dizzee stuff 33 1 Cars Posted August 4, 2013 we made the press we have from 4 RSJ's and a 20 tonne bottle jack, never failed yet. Share this post Link to post Share on other sites
stef205 96 1 Cars Posted August 4, 2013 My friend has made one from a tractor ram pushes/presses things like a hot knife through butter. It has a reversible valve for down and up and the pump is driven by a 12v motor very simple setup Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 I've got a Clarke floor standing press, does everything I want car wise Share this post Link to post Share on other sites
calvinhorse 870 Posted August 5, 2013 My friend has made one from a tractor ram pushes/presses things like a hot knife through butter. It has a reversible valve for down and up and the pump is driven by a 12v motor very simple setup That sounds absolutely lethal! Share this post Link to post Share on other sites
jord294 97 Posted August 5, 2013 (edited) I bought a 20 ton floor standing press when I started doing beam refurbs. Best money I ever spent! Even though it's mainly used for pressing trailing arm shafts in/out. It's a proper ram type. Not the cheaper bottle jack and spring type Edited August 5, 2013 by jord294 1 Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 He's looking at a ram type press?? Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted August 5, 2013 I've got a Clarke floor standing press, does everything I want car wise What rating is yours Allan? Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 Mines a 10 tonne, easily removes front/rear wheel bearings, trailing arm pins, seized torsion bars etc. The most important thing when you've got a press is having the right tooling/lumps of bar/old bearings to get stuff out with Share this post Link to post Share on other sites
Anthony 1,003 Posted August 5, 2013 Unless you really don't have the space, a floor standing press will be much more useful in my experience Alan. I've got a Sealey 20 tonne floor standing press, and it's been brilliant. A 10 tonne would have been sufficient, but I got this for the same price in a sale Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted August 5, 2013 I've got a Clarke floor standing press, Unless you really don't have the space, a floor standing press will be much more useful in my experience Alan. The most important thing when you've got a press is having the right tooling/lumps of bar/old bearings to get stuff out withThis x100. Having the press is all well and good but with no press tools you will quickly get frustrated. I have got a 1900 and 1600 front bearing old outer race with a section turned down to use as a pushing tool for installing new bearings. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 Tom, check the op's name Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted August 5, 2013 f***ing smart arse! Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 f***ing smart arse! f***ing retard! 4 Share this post Link to post Share on other sites
MiniGibbo 142 Posted August 5, 2013 I really want a press my self.. I'd probably go for a floor standing my self as it must be simpler to use Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted August 5, 2013 f***ing retard! Once you have got the difference between "left" and "right" nailed down then you can call me what you want! Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted August 5, 2013 Once you have got the difference between "left" and "right" nailed down then you can call me what you want! Nahh I'm on top of that one, had it tattoo'd on my hands didn't eye retard! 1 Share this post Link to post Share on other sites
Alastairh 47 Posted August 5, 2013 I also have a floor standing 10 ton clarke ram type press. I've raised the press off the floor 50mm for 306 torsion bars, which the 20 ton press covers fine. After 5 years use the ram seals did fail 2 months ago. Thankfully they aren't expensive but its a fiddily job. Al Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted August 5, 2013 I bought a cheap press off Ebay, it was less than £100 but is effectively identical to the Clarke items with a proper ram not a bottle jack and springs effort. Its a bench standing item and has always done what I required of it, however I cannot see why folk pay massively more money over the bench item for an extra 3 ft of steel to get a floor stander, my plan was if I ever required it to get a couple of 6ft lengths of steel channel and rebuild my bench press into a floor mounted press, never really had the need to do so yet. Share this post Link to post Share on other sites
