vern
Crank And Hockey Stick Seals
vern
Are the crank seal (flywheel end) and the hockey stick seals available separately from anywhere other than the main stealers?
pugpete1108
I may have a pair of hockey stick seals left from when I bought some before, ill double check in the morning.
I'm pretty sure I might have a crank seal knocking about too
ALEX
You usually get a pair when you buy a sump gasket
vern
Thanks for replies, PugPete if you could have a look and let me know.
Alex I have never seen a pair with just a sump gasket, just usually with a gasket set.
Crank seals can be had from any motorfactor as well as a dealer, hockey stick seals afaik a dealer only part.
Plus you have to buy a bag of the minimum quantity as well, iirc 10.
g
Yep, defo minimum quantity on the hockey stick seals unless you get a friendly dealer who'll split, and 10 sounds about right.
Given how much of a pain it is to replace the crank seal, it pays to spend a little extra and buy a quality/branded part than whatever the cheapest thing on eBay is.
indeed a branded item is better, however I have heard from a few that the dealer supplied seals aren't the best any more as they have changed the construction, miles or sandy may be able to comment.
S@m
I have 8 genuine psa hockey sticks left from my bottom end rebuild. Will do a pair for £2 delivered.
ALEX
No they're defenatley including these with the sump gaskets now. You even get the seal for the oil level ensor on early XU engines.
I'll try and source the manufacture, but I bought mine from my local motor factors http://www.samraparts.co.uk/
They can even source you the crank seals size for size, not OE replacements but will do the same job.
Edited by ALEX
vern
For the crank seals if not getting genuine, what are the makes to get from a motor factors that are proven good?
Sam will send you a PM about the hockey stick seals.
pugpete1108
Yeah I've had a look and can only find 1 hockey seal not 2 ???? and I'm guessing the crank seal is buried in a box somewhere
