Jemehan
S16 Plates - Help
Jemehan
Hey, a little emergency here....
Does anyone know the reg of a 306 s16? I need to get some parts and it makes everything easier to give motor factors a ref tu use, the engine I believe is out amid a mid 90s model if that helps. If anyone can give me a standard reg, it'll be seriously appreciated.
what are you after specifically?
try K878EYT, that's a ZX 16v, brakes and engine is the same as an S16.
M186YUD is a old 306 S16 of mine
Jemehan
Cheers! Means the garage can get the right parts for sure!! Sucks - get to holiday destination only for an idler bearing to start rattling, sods law!!
Wouldn't be so sure of that, The reg will still bring up a list of options, even at the dealers too
Jemehan
Garage say they found the parts, so hopefully, no issues? Will have to wait and see tbh...
dcc
Do these have the rubber lower pulleys too? If so, make sure they don't try to time it up with the old lower pulley, as the timing hole will have slipped. That is of course if its the same as the GTI6 crank pulley.
Nope, they have a hub and separate damper, pin is in the hub.
