dam205 2 Posted June 20, 2013 Right, ive removed most of the under seal from my 205 with a hot air gun, scraper and angle grinder. Problem is now im doing the rear of the car and with the beam removed its proving difficult to get into all the nooks and cranies. Anyone got any good ideas for removing the under seal from those hard to get places on the rear? By the way I know its easier to work on the car upside down but unfortunately im working underneath the car and cant flip it over! Any advice would be greatly welcomed Damon Share this post Link to post Share on other sites
Lan 24 1 Cars Posted June 20, 2013 remove the beam, 6 nuts + two brake pipes and two handbrake cables... easy Share this post Link to post Share on other sites
welshpug 1,626 Posted June 20, 2013 (edited) Blasting will shift it, but not really a DIY option for most, so just more elbow grease really! Not sure if anything like Nitromors will touch it. remove the beam, 6 nuts + two brake pipes and two handbrake cables... easy reading fail... Problem is now im doing the rear of the car and with the beam removed its proving difficult to get into all the nooks and cranies. Edited June 20, 2013 by welshpug 1 Share this post Link to post Share on other sites
Lan 24 1 Cars Posted June 20, 2013 Blasting will shift it, but not really a DIY option for most, so just more elbow grease really! Not sure if anything like Nitromors will touch it. reading fail... massive FAIL, its been a long day 9-9:30pm slinging the spanners + beers now i'm finished... time for bed clearly! Share this post Link to post Share on other sites
mowflow 67 Posted June 22, 2013 Unfortunately I'm just getting started on this job as well. I've tried heat gun and scrapers, flap wheels and twisted wire brushes on the grinder so far. There doesn't really seem to be any easy way of doing it unfortunately but if anyone knows of one (not blasting) then I'm all ears. Share this post Link to post Share on other sites
bigalthenutter 8 2 Cars Posted June 24, 2013 get the majority off then use a blow torch and just burn it off there is no easy way even blasting it wont realy work as it will eat through metal and bounce off the sealant where its thickest and it will destroy the zinc coating. Share this post Link to post Share on other sites
