benny205mi16
Which Clutch Cable?
benny205mi16
Help please,
I have done a search but I am still not sure.
I need a new clutch cable, mine has snapped.
My car is a 1.9 gti 1990 h reg.
it has I believe a BE3 gearbox (reverse under 5th)
When I look at the images for a cable listed as correct it shows the end which fixes to the pedal as having a fork end with a pin and split pin, but may car has a plastic end fitted which 'clips' into the pedal and the images which look like this are listed for a 1.4 car.
Can anyone help?
Which cable should I use, or do I have the wrong one fitted at the moment?
as above, sounds correct for a post 1990 car, the pedal is the same for an MA box.
benny205mi16
Thank you for your fast replies,
ill get one ordered.
