starky5 18 Posted June 14, 2013 Bit of an odd one, I'm changing my door locks so I only need 1 key for the car. Now with the old door lock it will lock the car on the central locking but when I fit my replacement I doesn't. It doesn't set off the central locking and it doesn't even lock the drivers door. It's like it's not turning far enough, looking at both the lock barrels together the old one does turn a tiny bit further. Is there and way to adjust the mechanism to get it working? It all seems to be fixed length rods so I could think how to sort it. Thanks for any help Share this post Link to post Share on other sites
welshpug 1,737 Posted June 14, 2013 got the door closed? Share this post Link to post Share on other sites
starky5 18 Posted June 14, 2013 (edited) Yea I tried with the door open and shut, not even a hint if it trying to lock either time Edited June 14, 2013 by starky5 Share this post Link to post Share on other sites
Anthony 1,003 Posted June 14, 2013 Is the plastic part on the end of the lock worn/sloppy? When they are, you can get a similar issue, as a portion of the key movement is taken up by the slack in the plastic rather than moving the locking rod. Share this post Link to post Share on other sites
starky5 18 Posted June 14, 2013 I thought that might be worn, there is a large amount of movement in the plastic before either lock barrel moves it. Are these available new do you know? Share this post Link to post Share on other sites
BlueBolt 156 Posted June 14, 2013 (edited) According to Servicebox you can get the complete new locks and keys from Peugeot still. You'll need the ID number of the key/lock though to be able to get it obviously. £57.05 for the lock £116.29 for the lock and key!! Edited June 14, 2013 by BlueBolt Share this post Link to post Share on other sites
starky5 18 Posted June 14, 2013 Thanks for the info, might hunt the scrapys and see if I can find a less worn one. I just bought the set of locks so do t really want to spend the same again on another lock haha Share this post Link to post Share on other sites
