m_attt 31 1 Cars Posted April 25, 2013 Can anyone recommend some switches to use with fans, and what gauge wire as mine have melted. regards Share this post Link to post Share on other sites
Anthony 1,003 Posted April 25, 2013 Fans are listed as 230W on XU models, so that's roughly 20 amps current draw each. If you must run manual fan switches and aren't using a relay setup, you'll want switches and wiring both rated to atleast 25 amp per fan. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted April 25, 2013 would that be the same for the aftermarket slimline ones. thanks Share this post Link to post Share on other sites
Anthony 1,003 Posted April 25, 2013 It's going to depend on the individual unit used, but Pacet fans for example are listed as a fair bit lower - 10.5 amp draw for their 12" thinline fan and upto 15.4 amp for their 12" Profan for example (on top of which you'd be wise to add a few amp safety margin in the switch and wiring) Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted April 25, 2013 ok thanks for the help, Ill go with 25a to be on the safe side. Share this post Link to post Share on other sites
Anthony 1,003 Posted April 25, 2013 Remember those figures are per fan, so if you're running a pair in parallel from the same switch you'll need to double the rating of the switch and any common wiring if you're switching them from a single switch! Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted April 25, 2013 will be replacing my existing setup, each fan on separate wire, just think the switchs were not up to it Share this post Link to post Share on other sites
