aarontrophy
Will Not Run Right :( 205 Gti 1.6 Help Please
aarontrophy
Hi I have a red 205 Gti 1.6
It's idles perfect revs spot on but when you drive it there is no power :(
I've changed the dizzy afm fuel rail ignition amp and coil still nothing compression check 150 over all 4
Someone must have had this problem
rallysteve
ignition timing out?
kyepan
cam timing? pin it and check everything lines up.
fuel pressure under load or a blocked fuel filter might also starve it.
what do the plugs look like colour wise?
aarontrophy
Plugs are black like its getting to much fuel, I haven't checked fuel filter is do they block up then? Timings all locks up nicely
I've tries a different fuel reg makes no difference at all :(
rallysteve
Did it run fine before you did something to it?
Mine had similar problems when I fitted a 1.9vac advance unit to a 1.6dizzy. Ran perfectly at idle and revved fine, however had no guts and wouldnt accelerate at all.
Steve
aarontrophy
I bought it as a non runner I will try the old dizzy again tonight
M_R_205
Did you manage to get this sorted??
I've got a 309 gti with exactly the same problem, its sat for 5 years, new fuel pump and plugs and it fired up, but as soon as you pull away it tries to konk out!!
based on what has just been said il try a new fuel filter tomorrow..
aarontrophy
Dizzy mate :)
Rich_p
Test the TPS.
I had one go on a 1.6 before and it was using tons of fuel and felt flat. It turns out it was reading wide open throttle constantly.
