aarontrophy
2.0 8V Turbo Headgasket Or Turbo Gone :(
aarontrophy
Hi all,
I left work today, when warming the car up it was puffing white smoke I decided to drive it to see weather it cleared and it got worse!
Been in touch with a couple people so said it could be head gasket, but I've never let it get hit the fans always kick in and out
Hope you guys can help cheers
dcc
Go get hydro carbons and compression check.
TooMany2cvs
Pull the intake plumbing off between turbo and manifold. Is that full of oil?
Is the coolant dropping?
aarontrophy
Was a blocked breather
NFS
Most likely that the gasket failed between the water and the piston causing you to burn water, is your water low? do you have a build up of pressure in the water tank?
