lfallgti 12 Posted March 31, 2013 Hi, As mentioned previously, ive recently bought a ph2.5 1.9, it was bought as a non runner and over this weekend ive fitted a low km engine, the engine is fitted fully and is running but the car being Aussie spec has aircon and also has power steering. My questions are; In the passenger wheel arch there is a canister type thing that I've not seen before when I owned uk cars, it has a pipe going from it about 500mm long with a loose jubilee clip that suggests it previously attached to something, but what? There is also an electrical connector about midway along the pipe that looks like it connects to a spare plug on the loom near the shunt box, if I go by this connection the pipe seems to want to connect under the throttle body, but I've never seen this setup before?? Also, I have two rad fans hence two grey plugs, where the f@ck do they plug into, I know it should be somewhere near the pass headlight but for the life of me can't see where they go???? Even the missus has been looking for the Poxy things, please help me. Lee Share this post Link to post Share on other sites
Ryan 99 Posted March 31, 2013 The canister is a charcoal canister fitted for emissions reasons. It feeds fuel vapour from the tank into the inlet to burn it off. UK cars just have an open breather on the tank instead. There should be a black box behind the passenger headlamp. The plugs for the fans should come out of the bottom of it. Share this post Link to post Share on other sites
welshpug 1,737 Posted March 31, 2013 charcoal canister, so the valve inline is just a solenoid valve operated by the ecu under certain conditions. a for grey plugs what are they like? stick a pic up! Share this post Link to post Share on other sites
lfallgti 12 Posted March 31, 2013 Ok, so the charcoal canister pipe should feed the inlet? Could this also be a connection on the throttle body as there is a spare outlet that will Fit? The fan plugs are the kind of flat two pin type, I'll try and get a pic up, but it's dark here now, I've seem them on my previous cars and they just Plug in near the inner wing iirc. Share this post Link to post Share on other sites
welshpug 1,737 Posted March 31, 2013 they sound like the main power feed for the fan system, Share this post Link to post Share on other sites
lfallgti 12 Posted March 31, 2013 Yes they have a big red (live) wire on them, I'll have another look in daylight and post some pics if i'm still stumped Share this post Link to post Share on other sites
lfallgti 12 Posted April 6, 2013 Found the plugs, we're hidden in the shunt box! Doh! Cheers Share this post Link to post Share on other sites
gerry 5 Posted April 7, 2013 Oooops thats my fault my bad forgot were I put them!! Share this post Link to post Share on other sites
