dobby909 2 Posted March 22, 2013 So my fuel lines are looking a little worse for wear now! i was considering just running a braided line direct from the fuel pump, through an inline filter and into the fuel rail...any issues with this idea?! its on a gti6 engine and by the looks of things there is a fuel return line? worth just running that as a braided line direct? Share this post Link to post Share on other sites
farmer 328 1 Cars Posted March 22, 2013 I just replaced mine with copper pipe. Share this post Link to post Share on other sites
dobby909 2 Posted March 22, 2013 yea ive thought of that too, but i take it there are no problem with my overall plan? Share this post Link to post Share on other sites
farmer 328 1 Cars Posted March 22, 2013 Am no expert but can't see why not. Share this post Link to post Share on other sites
dobby909 2 Posted March 22, 2013 sweet, i couldnt either but thought i better check! Share this post Link to post Share on other sites
Anthony 1,003 Posted March 22, 2013 Are you planning on running them through the car? If so, be warned that the pipe can "sweat" and the interior will stink of petrol. Share this post Link to post Share on other sites
HERMAN 33 Posted March 22, 2013 if you are wainting to use AN fittings on the fuel rail you will have to silver solder some fittings on. http://i661.photobucket.com/albums/uu332/HERMAN205/DSCF2994.jpg Share this post Link to post Share on other sites
dobby909 2 Posted March 22, 2013 my current fuel line is clamped on which as far as i can see is perfectly fine! anyway of stopping it from "sweating" Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted March 22, 2013 Yes ,use Teflon lined braided hose and AN. Fittings. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted March 23, 2013 Never use copper with modern fuel, Google is your friend if you want to find out why. Pipe wise as said you need the high quality pipe which isn;t cheap, If running inside the car then you need more fittings as well which bump the cost up, The std metal pipes from Pug are only £25.00 anyway Share this post Link to post Share on other sites
