GWtaylor
Oil Cooler Should It Have One
GWtaylor
Though all the 1.9's had oil coolers but mine doesnt and its deffo a 1.9 on a L reg
deathbringer929
not 100% sure but i think all 1.9 up to 1989 had oil coolers and 1990 onwards was deleted for a twin fan set up. someone else may be able to confirm?
No gti had twin fans unless it was aircon equipped.
AFAIK if it has PAS then it will more than likely have a remotely mounted oil filter and a heat exchanger linked off the top radiator hose, this will be just below the clutch arm bolted to the front of the gearbox.
Any non PAS non aircon manual 1.9 gti would have the Air-oil cooler I believe.
Edited by welshpug
GWtaylor
Thats cool then
Just checking that it wasnt supposed to have 1
PAS or no PAS it makes no difference, Some later 205's used a heat exchanger bolted onto the gearbox to get the oil upto temp quicker for emission reason's which removed the air cooled unit
allanallen
You don't need one.
You perhaps know more about his car than me but why doesn't he need one? I've recently fitted a standard cooler to my 1900 because it needed one.
Slo
Mine 1.9 never had any type of cooler whatsoever just the oil filter and that was it the oil never got to hot according to the guage
ORB
They are not oil coolers anyway. They are heat exchangers.
Slo
My turbo lump has one of those but i cant be arsed messing about with the water side so will be fitting an oil cooler to it instead
allanallen
Some cars came with 'air to oil' coolers
ORB
True, earlier 1.9s
They don't seem to do alot in my experience though!
allanallen
True, earlier 1.9s
I've fitted one to my road rally car and the oil temp now sits approx 1 and a half marks lower on the gauge when pressing on.
The original air-oil coolers are pretty efficient, could do with a thermostat tbf!
bondyshambles
I have a 1990 1.9 phase 1.5, none PAS and it has a cooler.
GWtaylor
Same my 1990 1.9 had a air cooled one thats what made me think
Simes
My current car doesn't have one, the only time it has got really hot is on track and i replaced the oil all most immediately. Since i no longer do track days the temp never goes over the 2nd mark. I've done 60,000 miles like this and driven up mountains at 35deg ambient. I do have an alloy finned sump though.
Rob_the_Sparky
Yeah, on the road I've never had a need for a cooler, I took mine off ages ago and not had an issue. The problem I see with the air-oil cooler is the lack of thermostat, so it is cooling the oil even when you don't want it to. If I were to put one back on I'd want to fit a sandwich plate with a stat rather than the stock one. Either that or retro-fit a water oil exchanger as these help heat the oil as well. Note: all for road applications though.
