mech205eng
Gti6 P/s And A/c Removal, Tensioner Question
mech205eng
I've removed p/s and a/c from the engine and am power the alternator with a 6pk 700 belt and going to tension it using the spare hole. What is the best tensioner to use? I have a 1.9 8v engine sat in my garage, i could steal the tensioner off this if that would be ideal? of maybe the old one off the 6 engine after i've changed the belt
jamie_1992
i used a cambelt tensiner off the gti6 engine
cheesegrater
206 tu 8V cambelt tensioner.
dcc
I used the s16/rallye aux style setup. and I have an adjustible rose jointed arm to take the tension
camgti
I didnt need any! I used a 6pk 705 and it had plenty of tension to turn everything with no slip. I had to manually turn the engine from the pulley to get the belt on but about half a turn and the job was done. Has been fine ever since.
Otherwise, I was going to use a spare I had form a timing belt change and it would have worked fine
Cam
