omri617
Most Hp I Can Get With Atmosphere Dkz 1.9
omri617
Hi guys
In my country , restrictions for upgrading engines with Turbo kits , NOS , Swapping engines etc - Are awful !
What are the upgrades man could make for 1.9 ? Anyone managed to get say 150 , 160 HP?
Carbs4me
i pretty sure some people have...
But you wont achieve more than that without TB's
omri617
TB's = Turbo? :blink:
What upgrades available I can go for?
Vili
You'll need set of high compression pistons, a cam, remap and custom exhaust manifold. That should get you close to 150 hp.
omri617
What would you choose , upgrading , or simply moving to Mi16?
Carbs4me
The Mi16/GTI6 route is probly the cheapest option
To get that sort of power out of the 8v, it will cost acouple thousand, maybe more?
By TB's i mean thottle bodies.
omri617
couple of thousands in the UK , means 4 in my country :(
Why suggest an engine swap when they have already stated that doing this in his country (Isreal) is a nightmare?
You should be able to get 150bhp for less than that price by careful assembly & use of the right bits but to guarantee that much & keep your standard motronic ecu might prove difficult.
I hope to have that from my engine but won't know until the car is finished & I take it for a power run when the engine has done some more miles but I'm on a different Motronic ecu to you.
g
omri617
Throttle bodies seem to be very expensive and affect mainly on hight rpm .
Which upgrades you have on your car Graham?
1.9 engine with 1.6 pistons, piper 272' cam & a lightly skimmed head with a four branch exhaust manifold & swapped ecu for the MP3.1.
g
omri617
Why 1.6 pistons?
Batfink
Higher compression. Throttlebodies will see most gains in the midrange but a gti-6 or mi16 conversion would be superior
Easy, you need TB's, ECU, Loom, Slightly worked head with larger valves, 285 spec cam, std bottom end will net you around 170bhp, Mind this will cost £3000.00 ish
DamirGTI
I made an cheap 1.9 8v engine with some 150 ish Bhp ?!? dunno how much it has but it's really quick and it feels while driving like something that's a combo of a 16v and turbocharged engine :blink: .. it revs up till the 7000rpm , and yet still pulls from the bottom like mad man ..
1. Gas flowed 1.9 8v D6B head (fully ovehauled)
2. Overhauled and lightened 1.9 8v DFZ bottom end (it has pistons with 9cc dish and compression height as much that it's almost flush with the liner when on TDC ! that boosts compression ratio and improves squish/quench ..)
3. Modified OE TB
4. Modified OE inlet manifold
5. 1.6 Flywheel
6. Uprated fuel pressure regulator
7. Recurved dizzy to match the engine specs
8. Custom made exhaust
9. Fuel mixture adjusted with an WB lambda sensor
10. 405 SRi box
It's still on Jetronic management ..
D B)
Edited by DamirGTI
omri617
sounds nice i envy you all
omri617
Sorry to bring this up , but I got to ask
D6B engine is available for me , for 150 GBP. except head , are there other parts can be good for me?
