350wedge 13 Posted January 8, 2013 Hopefully this is the right section for this..... Can someone tell me, will the standard wheel bolts used to attach the 1.6 GTi pepperpots also fit the 1.9 style Speedline/SMR wheel? Are they the same type and length?? Share this post Link to post Share on other sites
Ryan 99 Posted January 8, 2013 They will fit - the threads are the same size and length, and they're both flat-faced bolts. The only difference is that the 1.6 bolts have a longer head which will stick out slightly. Share this post Link to post Share on other sites
350wedge 13 Posted January 8, 2013 Excellent, thats just the information I need, and it explains why I've seen different things on Evilbay!! There are loads of bolt sets which are advertised as for 205's but have a taper on them. Assume these wont fit, shame really as they seem to be the cheaper sort.... Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 9, 2013 There are loads of bolt sets which are advertised as for 205's but have a taper on them. Assume these wont fit, shame really as they seem to be the cheaper sort.... No, you need the flat faced bolts for use with either of the standard alloys, 1.6 or 1.9, Speedline or smr. Taper seat bolts are cheap & easy to come by but generally only for use with either steel rims or some aftermarket alloys. g Share this post Link to post Share on other sites
Anthony 1,003 Posted January 9, 2013 Also, as a general rule, treat any claims or statements with regards fitment or compatability on eBay with a massive pinch of salt Share this post Link to post Share on other sites
350wedge 13 Posted January 9, 2013 Thats what I figured really, I've been on Ebay long enough to treat most things with a degree of suspicion!! I'm picking up a set of 1.9 alloys at the weekend to use as spares and will probably put them on the car at some point. Just making sure I have the right bolts really, I see I can pick up the flat bottom set for around the £30 mark. Share this post Link to post Share on other sites
