amusingadam
Oil Catch Tank
amusingadam
Fitting a oil catch tank to my 205 just wondering which breather you guys would use ie one on the rocker cover or another. car is 1.9 xu 8v 1987 Thanks guys
amusingadam
No, the mechnic i took my car to told me that i have a good build up of fuel vapour in the pipes, check this and cleaned them out he recomended a catch tank as this would limit the amount of build up im having (car was block tested for the build up came out fine)
Simes
If it's standard I'd leave it.
Otherwise if you have a 2 vent oil filler pipe - take the one that goes into the throttle body to your catch tank and then vent to air.
Don't vent the rocker cover.
amusingadam
Thanks will get my chap to take a look
